I have LC29H(BS) evk. Can I use this as a LC29H(DA) ?
I’m planning to use it(BS) as a rover, so to speak.
If possible, How can I configure it in QGNSS program? or some other way?
Can LC29H(BS) output nmea messages ? If can, how to config?
You can not use LC29HBS as a rover. The accuacy of a rover can not be guaranteed.
LC29HBS base station module doesn’t need to activate.
LC29HBS supports outputing these NMEA message. Above them, you can enable “PQTM” message by setting on PQTMCFGMSGRATE. I will send you related document via message.
Thanks for answer.
Manual says LC29H(BS) can ouptut NMEA 0183 V3.10/V4.10 ASCII.
but isn’t there command to output standard nmea messages (GPRMC, GPGSV, GPGGA… etc.) ?
The NMEA messages showed in content also refer to NMEA 0138 protocol. As you can see, LC29HBS supports input/output proprietary NMEA protocol (like PQTM and PAIR)
