Use L89 to get IRNSS only
Want to get location using IRNSS (NAVIC) constellation only.
$PSTMSETCONSTMASK,1024
This switches to IRNSS, but no satellite fix. Is there anything I am missing.
Thanks,
Milind
Dear Milind,
Below questions need your confirmation:
1, Provide the L89 firmware version: output when power on the module, like L89NR01A05XXXX.
2, Double check the ACK of $PSTMSETCONSTMASK,1024.
3, It would be better if you could provide NMEA log from the multi-GNSS to IRNSS only.
Best Regards
Dear Berton,
Please find the details.
1.
$PSTMANTENNASTATUS,1,0,14D
Sent >>>: $PSTMSRR
49
Recv <<<: $PSTMVER,GNSSLIB_8.4.13.20.10_EB3_ARM01
$GPTXT,L89NR01A03V02
25
Recv <<<: $PSTMVER,OS20LIB_4.3.0_ARM47
Recv <<<: $PSTMVER,GPSAPP_2.7_ARM
07
Recv <<<: $PSTMVER,BINIMG_4_5_11_10_EB3_ARM1B
Recv <<<: $PSTMVER,SWCFG_81055329
6F
Recv <<<: $PSTMVER,STAGPSLIB_6.0.0_ARM5A
Recv <<<: $PSTMVER,STA8090_622bc043
6F
$GPTXT,(C)2000-2018 ST Microelectronics29
25
$PSTMSETCONSTMASK,1024. – yes, it changes to IRNSS Constallation
$$GPRMC,000621.180,V,0000.00000,N,00000.00000,E,030917,N76
$$GPGGA,000621.180,0000.00000,N,00000.00000,E,0,00,99.0,100.00,M,0.0,M,60
$$GPVTG,T,M,N,K,N
2C
$$GNGSA,A,1,99.0,99.0,99.0
1E
$$IRGSV,1,1,04,802,00,000,29,804,00,000,26,803,00,000,26,806,00,000,2873
$$GPGLL,0000.00000,N,00000.00000,E,000621.180,V,N
4D
$$PSTMANTENNASTATUS,1,0,1*4D
Dear Milind,
The GNSS signal is a little poor, please put the L89 in the open sky. Also, please update the firmware and then have a try. Thank you.
The latest firmware: L89NR01A06 and the update tool: STA808x-9x Firmware Upgrade.exe:
Best Regards
Hi Berton,
I upgraded the device with the firmware. Now the device is not sending any data on Tx. Some garbage is continuously send. Cannot reprogram again.
Stuck with “Synchronising with target device”, when erase NVM and Recovery are selected.
Please advise.
Thanks,
Milind
Dear Milind,
1, When some garbage is send, please check the baud rate first.
2, When stuck with “Synchronising with target device”, please reset the L89 to sync.
Best Regards
Dear Burton,
It is not valid data, tested with oscilloscope.
“Synchronising with target device”, No response when RESET.
Please help.
Thanks,
Milind
Dear Milind,
Did you upgrade the L89 module as below:
When “Synchronizing with target device” occurs, please reset the L89 module to sync.
If this still cannot solve your problem, please provide more info so that I can help.
Best Regards
Dear Berton,
I have done it as shown in the figure. After the initial flash, I am not able to flash again (not responding to reset) nor the device is responding on the UART.
Thanks,
Milind
Dear Milind,
In order to resolve this problem more quickly, could you contact our local FAE for support? Or email to support@quectel.com . Thank you.
Best Regards
Hello @Berton.Peng-Q
I have same problem ,not able to upgrade firmware of L89 GPS.Tool stuck up @ synchronising with target device.And after reset device not responding. Thanks in advance!
May we also remark that IRNSS operates in the L5 band (1176MHz) so you’ll need a different antenna, please check.
Hi Milind, did you manage to solve this problem? my L89 module does not respond to any command, only respond when I add checksum and it RESPONDS BY $PAIR001,000,4*3F
this is the same responce for all commands
Can you explain me step by step how to use $PSTMSETCONSTMASK,1024 to enable IRNSS in L89 Quectel module and how to check ACK of this command?
