Is it possible to create a contiunous wave with an BC660?
I know there is the AT command AT+QRFTEST. Can i use that command on the BC660?
Or is there another similair command?
I have sent the document of this command to you, but this instruction usually needs to be triggered under the condition of strong sending and strong receiving
Which command do you mean, i cannot find it into the documents
I have sent it to you as a compressed file
Yes i saw the documents in the compressed file but they are the same as on the online document page of the quectel bc660.
In which document can i find that command?
I have resent a file named BC660K-GL_RF_FTM_Appliction_Note_V1.0.0_Preliminary_20231109 to you
i saw it, thank you.
Is it also possible to send a continuous wave or message to a specific Cell Physical Id?
No, FTM testing usually requires the terminal to be connected to the CMW500 for testing and cannot be tested under a real radio network
