Hi, I have a ftp server setup as only allowing connections over SSL/TLS. I use filezilla to connect to this ftp server with default port 21 and there is no issue at all. However, when I use EC200N to try connecting to the ftp server, it always report “606”, regardless of whether I try to connect via ftp or ftps. Please help!
I am using Qnavigator V1.6.9. I try both: 1)getting rid of the SSL configuration commands; or 2) set SSLtype to 0. I also try to set different values for the SSL versions. All come back with 606.
