Upload own combined firmware
I’m trying to, through QPYCom combine files option, combine the FW of BG95-M3 module with a own script named main.py.
When loads the same script through the file window and i reset the module, it works fine, execute the main.py. But, when i combine it with the FW provided by Quectel and reset the module it doesnt do anything. Is it necessary to upload some other files like a config one or something else?
In combine option, which cust_app.bin and efs2apps.mbn must be included?
Thanks a lot
hi
Thank you for your feedback
I confirmed with the internal team that QPYCOM does not yet support BG95M3 to merge scripts and firmware
This feature will be implemented in the next version of QPYCOM
(post deleted by author)
Thank you very much for your response. Do you know when the new version of QPYCOM will be released?
Any of the BG95MX modules supports the combination of firmware with scripts?
hi,
The new QPYCOM tool is expected to be available at the end of April or the beginning of May
I suggest that you can upload the script through QPYCOM first.
Please refer to the link below
QuecPython
