Hello everyone,
I have a problem upgrading MC60CA module using QFlashV6.8
Current version of my module is MC60CAR01A13 and I have a binary file named: MC60CAR01A15_UPGRADE.bin
Size of the file is 2790KB.
When I select it on QFlash nothing is added. What is the latest firmware for MC60CA? Is the file correct??
Hi
The MC60CAR01A15_UPGRADE.bin file in your hand is the upgrade file, which is used to support quecfota upgrade. If you want to upgrade with qflash, you need to select the cfg file, as shown in the following picture:
After selecting the cfg file, qflash will enter the burned file in the same directory
In addition, qflash6.8 version is too high, may not support burning MC60, you need to consider qflash4.0, qflash4.8
Thank you for your reply. ![]()
