tool: UpgradeDownload_R25.20.3901
BMAFrame DLL cannot be loaded。Try to download this DLL file to install registration, still can not run the program, need help
hello, could you tell us the module type and your current firmware version? thanks
module type:EC200U
Firmware version: EC200UCNAAR02A06M08_OCPU
Now the tools can not be opened normally, it has nothing to do with the module, suspected that I lack some files or did not install the driver caused by, but I heard our colleagues said that there is no need to install the driver
@Xiao_xiao_pang
可以试一试用管理员权限打开软件,如果还不行,可以换台电脑试试。
不过我们不推荐使用此软件进行烧录,请使用QFlash工具进行烧录下载。
Please try running the software as administrator, or check if the software runs on other computers.
However, we do not recommend using this software to download the firmware, please use QFlash for this.
就是在我的电脑上不能使用,我同事的电脑都可以,想找到解决使用此软件的方法。不想就给搁置了,不然全公司就我一个人不能使用此软件
@Xiao_xiao_pang
这个是电脑的问题,最方便的解决方法是重装或重置系统。也可以先试一试在 cmd 运行下述命令:
sfc /scannow
Hi @Victor.W
Do you have a guide to update QuecPython firmware using the QFlash tool?
