Hi, I am using evb g2. I would like to know if a firmware update is available. If available, how do I update?
Second question, why can’t I activate the engineering mode through the AT + QENG command?
You could use QFIL to update firmware, and what is AT+QENG response ?
When I run the AT + QENG command, it returns error.
why the command doesn’t work? Is it due to the failure to root the phone?
I also ask if you could pass me a newer firmware if available!!!
can you help me? We got stuck in development activities
pls add my skype live:76530067, let me send you , if command response is error, it is not supported
Hi, I have the same problem with same EVB and SC600. How can I resolve? Thanks in advance
