Hello Quectel Community,
I am working on a project that involves GNSS for time synchronization, and I am using the PMTK314 command to configure the NMEA sentence output frequencies. I have a specific configuration where I only enable the GPRMC sentence. Here are two variations of my configuration:
Configuration 1:
#define ONLY_GNRMC "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29\r\n"
Configuration 2:
#define ONLY_GNRMC "$PMTK314,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*2C\r\n"
In Configuration 1, the GPRMC sentence is set to output once every one position fix. In Configuration 2, the GPRMC sentence is set to output once every four position fixes.
Could someone explain the concept of a “position fix” in this context? Specifically:
- What does it mean to have a sentence output “once every one position fix” versus “once every four position fixes”?
- How does this setting affect the data output frequency and potentially the performance or power consumption of the GNSS module?
Any detailed explanations or references to relevant resources would be greatly appreciated. Thank you!
Best regards,
M
