I wanna use the hardware flow control in UART in BG95 module and I have sent (AT+IFC = 2,2) and read back the set value and getting the response (AT+IFC? +IFC 2,2 ok). After sending this command I was sending the 4096 Bytes of data over UART but after that module is not responding.
Please suggest me if I missed something or tell me what I need to add more so that It will work.
I am facing similar issue, BG95 module not responding when enabling HWFC.
Does anyone has idea what could be the issue?
Even i am facing this issue in BG96 on firmware BG96MAR04A03M1G_01.003.01.003 , try to set HW flow control .
AT+IFC=2,2
But checking it doesn’t show it as set at all ,
AT+IFC?
+IFC: 0,0
This is screwing up file operations through AT cmds in data mode …
HI any update on this issue ? im having the same problem with bg96
