Unable to switch to QMI mode on RM500U-EA
I’m trying to switch my RM500U-EA to QMI mode, but the card refuses the value:
AT+QCFG=“usbnet”,0
+CME ERROR: 4
I can only switch between MBIM (2) and ECM (1) modes.
Firmware version is RM500UEAAAR03A13M2G and the card is running on an aarch64 environment.
Thanks for any help.
Start from checking what is supported with AT+QCFG=?
Thanks for your reply:
AT+QCFG=?
+QCFG: "usbnet",(1,2,3,5,11,13,15)
+QCFG: "nat",(0-2)
+QCFG: "pm/wakeup",(0x0-0x1f)
+QCFG: "usbcfg",(1-65535),(1-65535),(0,1)
So you can see that the value of 0 is not supported.
I suggest using this modem in ECM mode with NAT off.
Thanks, I managed to get it to work with the following commands:
AT+QCFG="ethernet",0
AT+QCFG="usbnet",1
AT+QCFG="nat",0
AT+QNETDEVCTL=1,3,1
AT+CFUN=1,1
But after a reboot, I need to run the same commands again to get the interface up and running. Any idea how to get the settings permanent?
There is no need to repeat all these commands.
If your modem always starts with CFUN: 4 then I suggest you starting a separate topic on this particular issue.
I might have a signal issue, after performing a reboot, no more issue. Thanks @jfrog!
