Unable to get Voltage at USIM_VDD in EC200U-CN
Hello everyone,
I have designed a PCB for EC200U-CN module for my project according to the hardware design guideline files. Module is getting detected via USB but the voltage at USIM_VDD is 0V even when the SIM Card is present.
AT Command Responce:
ATI
EC200U
Revision: EC200UCNAAR02A10M08
AT+CFUN?
+CFUN: 1
AT+CPIN?
+CME ERROR: 10
AT+CSQ
+CSQ: 20,99
AT+CREG?
+CREG: 0,2
AT+CEREG?
+CEREG: 0,2
AT+COPS?
+COPS: 0
AT+QCFG=?
+QCFG: “nwscanmode”,(0,1,3),(0,1)
+QCFG: “band”,(0-FFFF),(0-7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF),(0,1)
+QCFG: “creg/emergency”,(0,1)
+QCFG: “pdp/retrytimes”,(0-10)
+QCFG: “qoos”,(0-2),(0-255),(0-255),(0-255)
+QCFG: “dftpdn”,<ip_version>,<apn_name>,<auth_type>,,
+QCFG: “airplanecontrol”,(0,1)
+QCFG: “qcsq/rssi/negative”,(0,1)
+QCFG: “nwparam/calib”,(0,1),(0,1)
+QCFG: “3gpprel”,(8-13)
+QCFG: “qcellinfo/fmt”,(0,1)
+QCFG: “usbnet”,(1,3)
+QCFG: “nat/cid”,(0-FFFFFFFF)
+QCFG: “nat/subnet”,(1-7),<net_address>,<subnet_mask>
+QCFG: “usbnetmac”,<mac_address>
+QCFG: “urc/ri/smsincoming”,(“off”,“pulse”),(1-2000),(1-5)
+QCFG: “urc/ri/other”,(“off”,“pulse”),(1-2000),(1-5)
+QCFG: “urc/ri/ring”,(“off”,“pulse”),(1-2000),(1-5)
+QCFG: “urc/delay”,(0-120)
+QCFG: “urc/cache”,(0,1)
+QCFG: “risignaltype”,(“respective”,“physical”)
+QCFG: “apready”,(0,1),(0,1)
+QCFG: “cmux/urcport”,(0-4)
+QCFG: “fota/cid”,(1-7)
+QCFG: “fota/times”,(0-120)
+QCFG: “fota/path”,
+QCFG: “pkalive/ip”,(1-2),<IP_address>,(0-65535)
+QCFG: “ledmode”,(0-2)
+QCFG: “led/sim”,(0,1)
+QCFG: “tone/incoming”,(0,2,3)
+QCFG: “sleepind/level”,(0,1)
+QCFG: “wakeupin/level”,(0,1),(0,1)
+QCFG: “ntp”,(1-10),(5-60)
USIM Interface Schematic:
TVS Array:
SIM Card Connector:
SIM card schematic design is no problem, according to the AT command can not identify the card, it is recommended to switch SIM card to try, check whether the contact is poor.
