Was able to connect and get NEMA data from the module with no problem.
as an example i just issued a cold restart command
$PQTMCOLD*
with checksum 1C and Advanced setting of ASCII / NEMA / CRLF
nothing happened.
[2024-11-07 19:19:27.175 Uart Rx:0254 B] $GNGGA,011930.300,3513.903327,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*42
$GNRMC,011930.300,A,3513.903327,N,09741.335228,W,0.015,357.09,081124,,,A,V*2D
$GNGLL,3513.903327,N,09741.335228,W,011930.300,A,A*52
$GNVTG,357.09,T,,M,0.015,N,0.029,K,A*24
**[2024-11-07 19:19:27.206 Uart Tx:0014 B] $PQTMCOLD*1C**
[2024-11-07 19:19:27.283 Uart Rx:0276 B] $PQTMCOLD,ERROR,3*77
$GNGGA,011930.400,3513.903327,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*45
$GNRMC,011930.400,A,3513.903327,N,09741.335228,W,0.015,357.09,081124,,,A,V*2A
$GNGLL,3513.903327,N,09741.335228,W,011930.400,A,A*55
$GNVTG,357.09,T,,M,0.015,N,0.028,K,A*25
[2024-11-07 19:19:27.379 Uart Rx:0254 B] $GNGGA,011930.500,3513.903328,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*4B
$GNRMC,011930.500,A,3513.903328,N,09741.335228,W,0.017,357.09,081124,,,A,V*26
$GNGLL,3513.903328,N,09741.335228,W,011930.500,A,A*5B
$GNVTG,357.09,T,,M,0.017,N,0.031,K,A*2F
[2024-11-07 19:19:27.487 Uart Rx:0254 B] $GNGGA,011930.600,3513.903328,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*48
$GNRMC,011930.600,A,3513.903328,N,09741.335228,W,0.018,357.09,081124,,,A,V*2A
$GNGLL,3513.903328,N,09741.335228,W,011930.600,A,A*58
$GNVTG,357.09,T,,M,0.018,N,0.032,K,A*23
[2024-11-07 19:19:27.581 Uart Rx:0254 B] $GNGGA,011930.700,3513.903328,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*49
$GNRMC,011930.700,A,3513.903328,N,09741.335228,W,0.014,357.09,081124,,,A,V*27
$GNGLL,3513.903328,N,09741.335228,W,011930.700,A,A*59
$GNVTG,357.09,T,,M,0.014,N,0.026,K,A*2A
[2024-11-07 19:19:27.674 Uart Rx:0254 B] $GNGGA,011930.800,3513.903329,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*47
$GNRMC,011930.800,A,3513.903329,N,09741.335228,W,0.009,357.09,081124,,,A,V*25
$GNGLL,3513.903329,N,09741.335228,W,011930.800,A,A*57
$GNVTG,357.09,T,,M,0.009,N,0.017,K,A*24
[2024-11-07 19:19:27.782 Uart Rx:0254 B] $GNGGA,011930.900,3513.903329,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*46
$GNRMC,011930.900,A,3513.903329,N,09741.335228,W,0.012,357.09,081124,,,A,V*2E
$GNGLL,3513.903329,N,09741.335228,W,011930.900,A,A*56
$GNVTG,357.09,T,,M,0.012,N,0.022,K,A*28
[2024-11-07 19:19:28.012 Uart Rx:1806 B] $GNGGA,011931.000,3513.903330,N,09741.335228,W,1,34,0.54,402.8,M,-25.0,M,,*41
$GNRMC,011931.000,A,3513.903330,N,09741.335228,W,0.013,357.09,081124,,,A,V*2F
$GNGLL,3513.903330,N,09741.335228,W,011931.000,A,A*56
$GNVTG,357.09,T,,M,0.013,N,0.024,K,A*2F
$GNGSA,A,3,02,07,13,14,15,17,19,21,22,30,08,,1.06,0.54,0.91,1*0F
$GNGSA,A,3,66,67,68,75,76,77,85,86,87,,,,1.06,0.54,0.91,2*0C
$GNGSA,A,3,02,07,15,27,29,30,34,36,,,,,1.06,0.54,0.91,3*03
$GNGSA,A,3,19,27,28,30,36,37,,,,,,,1.06,0.54,0.91,4*0F
$GNGSA,A,3,,,,,,,,,,,,,1.06,0.54,0.91,5*0B
$GPGSV,3,1,10,02,41,076,43,07,43,143,29,13,32,287,38,14,61,332,45,1*6F
$GPGSV,3,2,10,15,08,309,17,17,57,231,42,19,26,225,42,21,29,057,30,1*60
$GPGSV,3,3,10,22,46,303,45,30,77,166,37,1*60
$GPGSV,1,1,03,08,06,048,25,14,61,332,43,30,77,166,44,8*5E
$GLGSV,3,1,09,66,09,239,20,67,15,289,18,68,04,335,17,75,19,100,38,1*76
$GLGSV,3,2,09,76,58,035,44,77,35,326,31,85,18,029,36,86,62,080,40,1*75
$GLGSV,3,3,09,87,43,172,35,1*4B
$GAGSV,2,1,07,02,10,083,22,07,29,217,35,15,32,146,30,27,50,309,44,7*7E
$GAGSV,2,2,07,29,31,281,26,30,54,049,41,34,38,080,39,7*46
$GAGSV,3,1,09,02,10,083,20,07,29,217,32,08,00,176,21,15,32,146,28,1*7A
$GAGSV,3,2,09,27,50,309,43,29,31,281,33,30,54,049,45,34,38,080,44,1*78
$GAGSV,3,3,09,36,09,034,25,1*40
$GBGSV,2,1,06,19,04,251,15,27,71,111,41,28,35,048,33,30,38,199,28,1*79
$GBGSV,2,2,06,36,24,308,27,37,40,107,38,1*70
$GBGSV,2,1,06,19,04,251,24,27,71,111,45,28,35,048,34,30,38,199,33,5*76
$GBGSV,2,2,06,36,24,308,32,37,40,107,42,5*7D
$GQGSV,1,1,00,1*65
$GQGSV,1,1,00,8*6C
$GNGGA,011931.100,3513.903330,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*47
$GNRMC,011931.100,A,3513.903330,N,09741.335228,W,0.015,357.09,081124,,,A,V*28
$GNGLL,3513.903330,N,09741.335228,W,011931.100,A,A*57
[2024-11-07 19:19:28.075 Uart Rx:0254 B] $GNGGA,011931.200,3513.903330,N,09741.335228,W,1,34,0.53,402.8,M,-25.0,M,,*44
$GNRMC,011931.200,A,3513.903330,N,09741.335228,W,0.015,357.09,081124,,,A,V*2B
$GNGLL,3513.903330,N,09741.335228,W,011931.200,A,A*54
I have tried many different commands and get no reply.
From the screen the FW version is LC29HEANR11A03S_RSA
SN is P1Y24IM2H000013
It also shows:
11 GPS
6 BDS
9 GLONASS
8 GALILEO
but still does not show a fix mode.
It does show the Lat and Long except that the Longitude should have a - in front of it and it does not.
This appears to keep the map and 3d fix from working.
Can someone assist in a fix?
