Hello Community,
I am working on the Quectel BG-96 module using the LLVM compiler v4.0.
I have made all requied chnages in build_demo.bat file as given below.
set DAM_RO_BASE=0x43000000
set TOOL_PATH_ROOT=D:\test\SD_LLVM_ARM_WIN_4_0
set TOOLCHAIN_PATH=%TOOL_PATH_ROOT%\llvm\bin
rem echo TOOLCHAIN_PATH is %TOOLCHAIN_PATH%
set TOOLCHAIN_PATH_STANDARdS=%TOOL_PATH_ROOT%\llvm\armv7m-none-eabi\libc\include
set LLVMLIB=%TOOL_PATH_ROOT%\llvm\lib\clang\4.0.3\lib
set LLVMLINK_PATH=%TOOL_PATH_ROOT%\llvm\tools\bin
set PYTHON_PATH=%TOOL_PATH_ROOT%\Python27\python.exe
Trying to compile the examples codes for the BG-96 Open SDK.
The console logs for the compilation process are given below.
I am not able to understand only the .ini & .elf files are generated.
there is no .bin file in the /bin/ deirectory
Will you please help to solve this problem?..
Regards,
Shiv Patil.
