This modem is in PCIe mode, inside a GL.iNEt x3000 router.
I use Tmobile data sim card
It will connect to tower, i can see signal and band info but no IP address
Any logs about it?
Could you send AT?
Yes, i was able to send AT command.
I fixed it by
AT+QCFG=“data_interface”,1,0
AT+QCFG=“pcie/mode”,1
AT+QCFG=“usbnet”,0
AT+QMAPWAC=1
AT+CFUN=1,1
Any logs?
So you can send AT via USB now?
after doing my test, yes, thank you
It means that you try the Quectel modem with USB.
I don’t which way you would like.
If you need the USB, it should work now.
