Unable to enable network of Airtel IOT sim with BG95 in India
Hi, I’m Dhruv from India. I need to enable network on airtel iot sim if anyone having any sequence for bg-95 then please provide. thanks in advance.
BG95_Model_Details:-
ATI
BG95
Revision: BG95M3LAR02A03
AT+CPIN?
+CPIN: READY
AT+QSIMSTAT?
+QSIMSTAT: 1,1
AT+CFUN=1
AT+GSN
866088075363489
AT+CIMI
404909247918192
AT+QCCID
+QCCID: 8991900992479181928F
AT+CSQ
+CSQ: 99,99
AT+CREG=2
AT+CPAS
+CPAS: 0
AT+CGDCONT=1,“IP”,“airtelgprs com”
AT+CGDCONT?
+CGDCONT: 1,“IP”,“airtelgprs com”,“0.0.0.0”,0,0,0,0
AT+CREG?
+CREG: 2,0
AT+QCFG=“nwscanseq”,01,1
AT+QCFG=“nwscanmode”,1,1
AT+QCFG=“band”
+QCFG: “band”,0xf,0x100002000000000f0e189f,0x10004200000000090e189f
AT+CSCS?
+CSCS: “GSM”
AT+CREG?
+CREG: 2,0
AT+COPS?
+COPS: 0
AT+QNWINFO
** +QNWINFO: No Service**
** OK**
** AT+QCSQ**
** +QCSQ: “NOSERVICE”**
** OK**
AT+CGATT?
+CGATT: 0
Hello @busadhruv
is it possible you might be missing a dot in the APN? According to this article the APN is airtelgprs.com. You seem to have set it to airtelgprs com.
Felix
NO i didn’t missed that dot in actual command.
I am new to this so when i post this article it is showing that new user can’t paste more then one link so that’s why..
Hello @busadhruv
ok, I see. Well, the first time it can take several minutes for the modem to scan all frequencies and search for a provider.
Have you considered to issue AT+COPS=? - this should give you a list of available providers in your region. (This command also takes quite some time.)
Felix
P.S. Yes, I understand, I ran into the ‘can only post twice to a given topic’ rule myself.
here is two outcomes from different places
but didn’t find Airtel.
1) AT+COPS=?
AT+COPS=?
+COPS: (3,“IND-JIO”,“JIO”,“405857”,9),(0,1,2,3,4),(0,1,2)
2
Hello @busadhruv
Ok, so your first scan result:
+COPS: (3,“IND-JIO”,“JIO”,“405857”,9) means: 3 - operator forbidden; 9 - NB-IoT
Your second scan results:
+COPS: (3,“Vi India”,“Vi India”,“40405”,0) means: 3 - operator forbidden; 0 - GSM
+COPS: (3,“CellOne”,“CellOne”,“40457”,0) means: 3 - operator forbidden; 0 - GSM
+COPS: (1,“IND-JIO”,“JIO”,“405857”,9) means: 1 - operator available; 9 - NB-IoT
So I am a bit confused as IND-JIO in the first scan signals forbidden and in the second scan signals available.
I think you might need to verify to which provider your SIM card is allowed to connect to.
Felix
P.S. I probably will hit the post limit for new users in this topic with this post as well.
So first scan result has been done at different place as compare to second one. so, is this reason that showing at forbidden and available and above results are shownig that bg95 module finds the available network in my area.
Dhruv
Now close this discussion here i found issue where antenna is not properly connected that’s why the BG-95 module didn’t capture proper network signal Now i connect the antenna properly and everything works fine for me..
