Unable to connect using mTLS and M66 MODEM
I have a M66 MODEM with revision: M66FCR01A20BT
I followed the application note “GSM SSL application note V3.4” and know how to upload the certificates and key.
I am currently able to establish a connection to a TCP server in both TCP mode and in TLS set to no authentication (seclevel=0).
I would like to be able to connect with mutual authentication level (mTLS) so I set seclevel=2
The server I want to connect to is tcpbin.com:4244.
The tcpbin.com page provides everything the client should and I tried to do both
a) I generated the client certificate and client key with the script provded on tcpbib.com, then I downloaded the root CA and loaded it into the MODEM
To load the root CA certificate into the modem I used AT+QSECWRITE= “RAM:CA0”,,
followed by the data and I received the confirmation with the checksum
Then I loaded the client certificate into RAM:CC0 in the same way
and the key into RAM:CK0.
I finally set the files with
AT+QSSLCFG=“cacert”,0,"RAM:CA0
AT+QSSLCFG=“clientcert”,0,"RAM:CC0
AT+QSSLCFG=“clientkey”,0,"RAM:CK0
b) I tried generating a certificate and signing it with the key and root certificate provided by tcpbin.com and uploaded it along with the private key I used to generate it.
Unfortunately, none of these attempts worked.
Could you kindly help me understand where the problem lies?
Thank you
Marco
