I have a “UMTS & LTE EVB Kit” and on this a UG96 module. On the board there is a SD card holder
where I have put a SD card. In a folder called “Picture” I have put some files. When I try to list
those files with
AT+QFLST=“SD:*”
I get error code 425.
Can anyone point me in some direction on how to get the SD-card in operation…
Cordially Yours
// Göran Hasse
Dear Göran,
According to your description, please to check the following aspects:
- Check whether your SD card is damaged or not before insert SD card to holder or SD card was not inserted correctly to holder.
- According to response code:425, it means invalid parameter, whether quotes format is right, it should be input in the state of English input method.
AT+QFLST=“SD:*”
please refer to the following doucument:
Quectel_WCDMA_UGxx_FILE_AT_Commands_Manual_V1.3.pdf (1.1 MB)
Dear Göran,
Please note that UG96 module can not support SD card function
