UDP Service on BG95-M3
Hello I’m trying to get the UDP service to work on BG95-M3. I need a Downlink option to send messages to our devices (using our operators backend for this).
I have been able to setup uplink using USB ecm and coaplib to setup DTLS and send CoAP messages.
I’m trying to setup downlink now by configuring a UDP service: What I got to work using BG95-M3 with firmware BG95M3LAR02A03_A0.301.A0.301
  • Socket opens successfully: AT+QIOPEN=1,0,“UDP SERVICE”,“127.0.0.1”,0,3000,0
  • Socket state shows correct: +QISTATE: 0,“UDP SERVICE”,“xx.xx.xx.xx”,0,3000,2,1,0,0,“usbmodem”
  • Backend shows messages are sent
  • But: No +QIURC: “recv”,0 URC is generated
  • And: AT+QIRD=0,1500 returns +QIRD: 0 (no buffered data)
I’m using the proper port and proper IP address (through our operators backend)
flow is like this:
AT+QGMR
AT+QIACT?
AT+CEREG?
+CEREG: 0,5
AT+QIACT=1
AT+QIACT?
+QIACT: 1,1,1,“xx.xx.xx.xx”
+QIOPEN: 0,0
AT+QISTATE?
AT+QIRD=0,1500
+QIRD: 0
AT+QIRD=0,1500
+QIRD: 0
I obfuscated the IP addresses (xx.xxx.xx.xx), but they are valid (was able to check them on operators backend)
Kind regards,
Hi @Luc
So, Have you Specified remote port and remote service when you send UDP data to UDP service?
I’m sorry, I’m not using this anymore. I have setup the device in ppp mode, which solves my issues to receive messages when connected to an embedded Linux system.
