Hi, I’m testing a custom board with a BG96 module and a STM32L0 MCU. I already have made a TCP/IP connection with a server and send data.
My problem comes when I try to send data over a UDP socket, I can open the socket and send data, I check with AT+QISEND command and all the data goes out but I don´t receive anything in my server.
I think there are restrictions using AT commands (even I haven’t found any documentation). Especially if you try to send using AT+QISEND you cannot use special characters like , or \r or \n.
This it a bit annoying as these are used in HTTP requests. Any workaround?
