I’ve recently got a new RM520NGLAA-M20-SGASA with RM520NGLAAR03A03M4G
I put it in a Khadas VIM4.
The pcie driver does not load correctly - I only see 1 mhi_device
/dev/mhi_BHI
And no
/dev/mhi_LOOPBACK , /dev/mhi_DUN /dev/mhi_MBIM etc
When I replace the device with one running older firmware I see all the mhi_ devices.
I notice that dmesg contains this:
[ 43.907416] mhi_init Quectel_Linux_PCIE_MHI_Driver_V1.3.7
[ 43.908037] Failed to set up IOMMU for device 0000:01:00.0; retaining platform DMA ops
[ 43.908078] mhi_pci_probe pci_dev->name = 0000:01:00.0, domain=0, bus=1, slot=0, vendor=17CB, device=0308
Can you please tell me what the problem might be - I can go back to the board maker if needed…
I need to use the newer firmware to access e-sim features.
Here are some logs for r01 and r03 firmware…
r01dmesg.txt (6.2 KB)
r03dmesg.txt (5.0 KB)
