I have been trying to connect the quectel bg95-m3 to UART for a while now and expecting to recieve responds from sending AT-commands. The problem is that UART never responds, even if I try to replace the BG95-M3 with a new one.
If there are any suggestions or example codes you know of that could be of help, please let me know. I just want to make the modem communicate via UART and respond to AT commands, nothing else.
Here is a picture of the hardware, it is connected via Raspberry Pi Sixfab Base HAT:
Thank you for your help. I noticed that the base hat does not work with the BG95-M3 modem. However when i use a normal PCI-E to PCI-E adapter, it still does not work. Do you know why that may be?
