When I try to start two different bc68s at the same time, one of them always interrupts the data transmission. the device that interrupts the data transmission Cereg: transmits the answer 0.4 how can I solve this problem?
Can you provide the relevant Log?
How to get module logs for bc68
Unfortunately, I do not have access to the module logs. However, when I try to connect two different devices to io.adafruit.com, the other one gives qmtstat=0.1 at at+conn= stage
these are different devices. Left and Right side
This problem is difficult to analyze and judge, the result is that the MQTT connection is interrupted; I recommend that you use another MQTT server for verification
so what is the reason for cereg 0.4 answer
+cereg:0,4, It is common when the terminal is in a weak signal environment, I need to debug log to determine
[2023-08-01_16:41:15:654]Quectel
[2023-08-01_16:41:15:654]BC68
[2023-08-01_16:41:15:654]Revision:BC68JAR01A10
The module I have says JAR02, but the answer that comes with the ATI command is as above. Can you send me the updated BC68 firmwares for me to update please.
BC68 has been discontinued and I can’t find the corresponding firmware
