Trouble Leaving PSM with BG95-M3
I’m having some issues with canceling or removing myself from PSM.
Often times even after turning off PSM, my devices (tested only multiple BG95-M3) will re-enter PSM mode.
Often to get out of PSM mode, I have to spam AT+CPSMS=0 or AT+QPSMS=0 repeatedly.
Checking the status is not guaranteed either that I am fully out of PSM, as It appears that I can enter PSM again at any moment.
Any assistance would be greatly appreciated.
# DEVICE
BG95-M3
Revision: BG95M3LAR02A03
# CONSOLE OUPUT
(11:49:23.288) (2.942) (<<) AT+QPSMS=1,,,"00100100","00011110"
(11:49:23.432) (0.144) (>>)
(11:49:23.432) (0.000) (>>) OK
(11:49:26.379) (2.946) (<<) AT+QPSMS?
(11:49:26.508) (0.129) (>>)
(11:49:26.508) (0.000) (>>) +QPSMS: 1,,,"17400","60"
(11:49:26.508) (0.000) (>>) OK
(11:49:29.577) (3.068) (<<) AT+CPSMS=0
(11:49:29.708) (0.130) (>>)
(11:49:29.708) (0.000) (>>) OK
(11:49:31.324) (1.616) (<<) AT+QPSMS?
(11:49:31.438) (0.114) (>>)
(11:49:31.438) (0.000) (>>) +QPSMS: 0,,,"14400","60"
(11:49:31.438) (0.000) (>>) OK
(11:49:38.262) (6.823) (<<) AT+QPSMS?
(11:49:38.385) (0.122) (>>)
(11:49:38.385) (0.000) (>>) +QPSMS: 0,,,"14400","60"
(11:49:38.385) (0.000) (>>) OK
(11:49:46.633) (8.247) (<<) AT+QPSMS?
(11:49:46.750) (0.117) (>>)
(11:49:46.750) (0.000) (>>) +QPSMS: 1,,,"17400","60"
(11:49:46.750) (0.000) (>>) OK
(11:50:29.987) (43.236) (<<) AT+CPSMS?
(11:50:30.098) (0.110) (>>)
(11:50:30.098) (0.000) (>>) +CPSMS: 1,,,"00100111","00011110"
(11:50:30.098) (0.000) (>>) OK
(11:50:38.551) (8.453) (<<) AT+CPSMS=0
(11:50:38.661) (0.109) (>>)
(11:50:38.661) (0.000) (>>) OK
(11:50:44.213) (5.552) (<<) AT+CPSMS?
(11:50:44.340) (0.127) (>>)
(11:50:44.340) (0.000) (>>) +CPSMS: 0,,,"00100111","00011110"
(11:50:44.340) (0.000) (>>) OK
(11:50:53.969) (9.629) (<<) AT+CPSMS?
(11:50:54.084) (0.114) (>>)
(11:50:54.084) (0.000) (>>) +CPSMS: 1,,,"00101000","00011110"
(11:50:54.084) (0.000) (>>) OK
Hi @sstenzel
This is happened on QuecOpen solution or Standard solution? probably you called PSM API?
please help check this firstly.
Greetings,
I don’t know that I fully understand the question as I am unsure what QuecOpen is.
This is happening when just using PSM via AT commands with a BG95-M3. The above was run via a serial connection to the device.
Thanks,
Hi @sstenzel
Thats so strange we have never met before, is possible to collect modem log for us?
Sure can you walk me through the process of what you need?
Yes, sure.
BTW, we need connect USB to collect log, is available to connect usb in your device? then i can share you guide and tool.
Yes, I have usb access, and have the Quectel drivers installed.
I am ready, please share the tools and guide, thanks.
Hi @sstenzel
Sorry for the late response due to buiness trip.
Tool:
Guide:
