Hello Team,
I am rookie but interested in IoT tracker, I have existing GSM tracker which looks outdated but I found the concept interesting. I have a BG95 dev kit and I would like to know how I can achieve the following. Can you please help ?
Call the SIM card phone number in tracker,you will receive a Google Maps link of position,
or sending message “G123456#” to SIM card phone number in tracker .
E.g:
SMS Configuration
1.1. Admin number setting (After admin number setting, all SMS operations to the device are under thisnumberonly.)
Command: admin123456 phone number(This phone number is your own mobile phone number , not theSIM card number in tracker .)
Reply:admin ok
E.g:admin123456 13265790180
1.2 When the unit is in over-speed alarm, shake sensor alarm, or low battery alarm, it will send alert totheadminnumber.(13265790180)
Admin number Canceling:
Command :noadmin123456
Reply:noadmin ok
1.3. Over-speed Alarm setting(It works only in continuous positioning mode.)
Over-speed Alarm setting:
Command :speed123456 070(Suppose speed is 70km/h)
Reply:speed ok
E.g:
When the unit speed is over 70km/h, it will send message “speed alarm!” to the admin number every5minutes. Over-speed Alarm canceling :
Command :nospeed123456
Reply:nospeed ok
1.4. Shake Alarm setting
Command:vib3,3
Message Reply:OK! Vibration xyz:3 Alarm
Mode:Call&SMS
E.g:
(Tracker only works for 5 minutes after being waked up, and back to sleep mode, GPSshut off, GSMworks in low consumption mode. SMS command, calling tracker can wake up the tracker.)
1.5 Sleep by shock sensor mode setting: (Factory setting is “Sleep by shock mode“)
Command:sleep123456 shock
Reply:sleep shock ok
E.g:
(No shock for 5 minutes, the tracker will work in “sleep by shock” mode, GPS shut off, GSMworksinlowconsumption. Vibration, SMS, calling can wake up the tracker.)
1.6 Monitor (Voice Surveillance),after device received the command, it will call back to the adminphone. Command: jt
Not Reply
1.7 Terminal (local) Time Setting(factory setting GMT 0)
Command:timezone123456, local timezone
Reply:time ok
E.g: timezone123456 ,1 timezone123456, -1 Timezone123456,8
1.8 Reboot Device
Command:RST
Reply:The tracker will immediately restart !
E.g:RST
1.9 Upload Interval Setting. Setting the rate of reporting the GPS location information to server. Command: Upload123456 30 ( The Value Range 10—300S)
Reply:Upload Ok
E.g:Upload123456 30
1.10 IP and Port setting. Command : szcs,123456,domain=211.162.69.241:7700
Reply: SET IP OK! IP:211.162.69.241#7700#
E.g: szcs,123456,domain=211.162.69.241:7700
