I’m using the BG95 mPCIe module with firmware BG95M3LAR02A03_01.200.01.200. SIM is on Telstra NB IoT in Australia. I can initialise the network connection without errors, but HTTPPOST or HTTPGET result in CME ERROR 702. Or sometimes DNS error, but if I avoid DNS (i.e. use IP addresses instead) then it’s always 702.
I have tried factory reset (AT&F). I’ve tried changing transpktsize, sack, tcp/retranscfg, nothing seems to make any difference.
Last week I had one module which could successfully HTTPPOST but only once immediately after connecting to the network, any post after that would get 702. That same module and firmware won’t work today.
CREG is successful, CEREG is successful, AT+QIACT? is successful. Some other status info:
+QCSQ: “NBIoT”,-55,-67,187,-10
+QCFG: “celevel”,0
+CSQ: 29,99
+QNWINFO: “NBIoT”,“50501”,“LTE BAND 28”,9502
Anyone else had any similar issues?
