Tftp client on M66 module
Good day.
I’m initialize the module in this order
QIMODE=0
QICSGP=1
CREG?
QIFGCNT=0
QIAUTOS=0
QIMUX=1
QIACT
After initialization I try to get a file from a TFTP server. I connect to it:
AT+QIOPEN=“"UDP","xxx.xxx","69"”
CONNECT
Аfter sending the “Read request (RRQ)”,
Details:“\0\001main.cpp\0octet\0tsize\00\0
I get a response. It’s okay for now.
Details:”\r\nRECV FROM:XXX.XXX.XXX.XXX:36876\r\n\0\006tsize\02451"
Please note that the transport port of server is different 36876.
Accordingly, I need to send data to this port (using the transport port of my original connection), but I can’t do it.
Creating a second connection to this port (and sending data through it using QIMUX=1) does not give the desired result, since the sender transport port changes.
Here are the questions.
  1. How can I find out the transport port of the QUECTEL module of the created connection (I would try to create a server on this port and send data from it)?
  2. Maybe everything is much simpler and I’m missing some command when I create a connection?
  3. There are no implementations of the TFTP client on the QUECTEL modules on the Internet. Is this really not possible or am I just looking bad?
Unfortunately, although the M66 module supports UDP protocol, but does not support TFTP protocol, I think the port error is probably because the transmission protocol does not match, you can find an HTTP server to try
