'Telegram' connection with UG95 module
We are trying to use the ‘Telegram’ messaging service with the UG95 module.
I communicate with the UG95 module via the serial port and AT commands.
I cannot open the connection and get an error when opening.
I used the 'Quectel_WCDMA_UGxx_SSL_AT_Commands_Manual_V1.2.pdf’ document as a reference.
I use the following commands:
AT+CPIN?
Response: +CPIN: READY
AT+CSQ
Response: worst 9, best 15
AT+CREG?
Response: +CREG: 0:1
AT+QISGP=1,1,“internet”,“”,“”,1
Response: OK
AT+QIACT=1
Response: OK
AT+QIACT?
Response: IP address, etc
AT+QSSLCFG=“sslversion”,1,4
Response: OK
AT+QSSLCFG=“ciphersuite”,1,“0XFFFF”
Response: OK
AT+QSSLCFG=“seclevel”,1,0
Response: OK
AT+QSSLCFG=“ignorelocaltime”,1,1
Response: OK
AT+QSSLCFG=“cacert”,1,“RAM:ca.pem”
Response OK
AT+qsslopen=1,1,1,“api.telegram.org”,443,1
Response OK
Response: QIOPEN, 1:550 → PROBLEM!!!
I do not send data yet, because I cannot open the connection.
I tried various combinations like ports 80,443 and settings with QSSLCFG like setting the security levels to 0,1,2.
I think my SSL config is not set up correctly!
Any help will be appreciated!
TIA
Jan
Dear Sir,
For your issue, it is better to check the following possible reasons. Thanks!
Thanks sir,
I will try this.
regards
