I’m new to Quectel and I started with MC60. Using Qnavigator, I’m testing TCP/UDP section. I set APN to mobile.vodafone.it: how can I configure Server ip and Server port?
You could find relate document in https://www.quectel.com/productdownload/MC60.HTML
./MC60/Common/Quectel_GSM_TCPIP_Application_Note_V1.2.pdf
Best Regards,
Hi willie Yao,
I had already consulted, but without finding the solution…
AT+QIOPEN=”Protocol”,”IP Address”,”Port”
e.g.: AT+QIOPEN=“TCP”,“220.180.239.212”,8007
Is this what you need?
I send this command but the log is “Fail to connect to server!”
You need ti check network registration status first.
AT+CGREG?
AT+COPS?
And activate PDP context:
AT+QIREGAPP
AT+QIACT
AT+QILOCIP
If you expect to get IP, you should be eble to connection a TCP server. The precondition is the port of the server is acceptable for incoming TCP connection.
That’s test server is in China office. Sometimes it’s off-line. You testing procedure has no problem.
it is not clear to me how / where to find a tcp server and its port
If you just want to test TCP conenction. You can test any website like www.google.com, port 443 or port 80
AT+QIOPEN=“TCP”,“www.google.com”,80
Hi
We have quectel EC25E LTE module connected to Raspberry pi by Sixfab Base HAT . We want to make TCP and UDP port forwarding to remotely access a server defined on Raspberry pi. We tried AT+QFWDSERVER but as we can understand it opens a port on modem only. It does not forward any packet to raspberry side. Could you please support the method to make the port forwarding. Does EC25E support port forwarding?
