Hi Quectel Team,
We have set up the Bc660k-GL module with Freertos cellular library. We work with a STM32, wiich sends commands to the quectel NB-IoT module. Sometimes, mostly after a STM32 reseset, we have following error, which gets repeated over and over again. Do we need to close the mobile connection? Or do you have an idea on how to continue here? Thanks
1756983077] [ERROR] [CellularLib] [_parseSocketOpenNextTok:112] _parseSocketOpen: Socket open failed, conn 0, status 566
[1756983077] [ERROR] [TCP Sockets] [TCP_Sockets_Connect:705] Socket connect timeout.
[1756983077] [ERROR] [MbedtlsTransport] [TLS_FreeRTOS_Connect:676] Failed to connect to … with error -6.
[1756983077] [WARN] [mqtt_agent] [vMQTTAgentTask:1148] Connecting to the mqtt broker failed. Retrying connection in 10300 ms.
[1756983088] [INFO] [mqtt_agent] [vMQTTAgentTask:1121] Attempting a TLS connection to …com:8883.
[1756983123] [ERROR] [CellularLib] [_parseSocketOpenNextTok:112] _parseSocketOpen: Socket open failed, conn 0, status 566
[1756983123] [ERROR] [TCP Sockets] [TCP_Sockets_Connect:705] Socket connect timeout.
[1756983123] [ERROR] [MbedtlsTransport] [TLS_FreeRTOS_Connect:676] Failed to connect to … with error -6.
[1756983123] [WARN] [mqtt_agent] [vMQTTAgentTask:1148] Connecting to the mqtt broker failed. Retrying connection in 70600 ms.
[1756983194] [INFO] [mqtt_agent] [vMQTTAgentTask:1121] Attempting a TLS connection to …
