Is it possible to manually schedule task or in general doing task management (creation, killing etc) in OpenCPU?
NO for OpenCPU, YES for ThreadX
M66, MC60/M OpenCPU tasks is pre-defined in custom_task_cfg.h
you can only enable/disable task (once)
Thnx mate, one more thing, is the names (proc_subtask & subtask id) are fixed?
this struct is “auto” enumerated for taskID 0 or 1 from beginig, you can print proc_task argument to see
proc_main_task, is application main task
proc_reserved1, for RIL (user hidden) { if you disable this two tasks you can not use RIL }
proc_reserved2, for RIL helper (user hidden)
proc_subtaskX is user-ware sub tasks
I have linked question.
How task scheduling works in OpenCPU ? There is any preemptive algorithms, any different task priorities and so on ?
Unfortunately, official guide even doesn’t mention, what RTOS used…
I did a small experiment. We have two tasks, and first sends to second some message through Ql_OS_SendMessage
It looks like second task runs only when first paused (for example, calls Ql_OS_GetMessage()
It is always correct, or in any circumstances second task can interrupt first task ?
RTOS: nucleus(M66, MC60), FreeRTOS (BC66)
if tasks priorities are equal - you must block task to switch other…
Ql_sleep() blocks too
Georgi, thanks!
It looks like priorities for all user tasks are equal (and have values DEFAULT_VALUE1
or DEFAULT_VALUE2
And do you know message queue length ? Or it dynamically get additional space from heap ?
Also anyone have troubles with heap memory fragmentation ? (sorry, i dont have any expirence with small systems with MMU).
yep DEFAULT_VALUE1 или DEFAULT_VALUE2 (stack and prio)
task queue length is const and a little ( I do not remember … ask Quectel )
fragmentation: this Mediatek SDK is older than Android and probably the most used SDK for gsm phones and modules … for user-ware use, I didn’t notice any problems
not have MMU…
BG9x ThreadX modules have MMU
MC60’s message queue length is up to 30. Thanks!
Good thread, thanks for info!
Even after 4 years, OpenCPU is still a reliable choice for task management in IoT modules. It’s impressive to see how technology evolves over time.Regarding task management in the nonprofit sector, it’s important to keep up with the latest tools. While the forum thread may have aged, the need for efficient project management in nonprofits remains crucial. Platforms project management software for nonprofits continue to adapt and improve their features to meet the changing demands of organizations. Exploring modern project management software can be a smart move for nonprofit organizations seeking to enhance their productivity and impact.
