Hi Quectel friends,
I am trying to use minicom to talk to my EM12-G. Somehow I cannot see my command in the interactive shell, but I can see the response of command AT.
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB3, 11:30:24
Press CTRL-A Z for help on special keys
I must failed to config the EM12-G correctly. Can someone elaborate me w.r.t. that?
I see the same behavior for /dev/ttyUSB2, and /dev/ttyUSB1 and /dev/ttyUSB0 has no response.
jfrog
April 18, 2024, 7:07pm
3
What if you first send ATE ?
Your AT command port is USB If#= 2, in the absence of other serial devices it will correspond to the 3rd interface (/dev/ttyUSB2).
I tried ATE? in /dev/ttyUSB3 and after that I can see the command I type in.
ERROR
AT
AT
AT
typing ATE? in /dev/ttyUSB2 didn’t help me though - this interface usually got stuck after a while.
Do you happens to know any other configuration that I might have missed?
jfrog
April 18, 2024, 7:44pm
6
? is not a part of the command, it is the ending of the sentence.
Thanks, I think after ATE I see the ttyUSB3 works with AT commands consistantly
Do you happens to know the series of AT commands that can help me connect the EM12-G to LTE network?
If AT+CGDCONT? shows that the correct APN is configured for context 1, then just switching to ECM mode with AT+QCFG="usbnet",1 may be all you need.
You can use the +CGDCONT command to set the APN if the MBN mechanism hasn’t beaten you to it.
Before setting ECM mode, read the current value for reference with AT+QCFG="usbnet"
jfrog
April 18, 2024, 9:35pm
10
First check what is the current state with
AT+CEREG?
AT+CGPADDR
Thanks, I’ll try it out and update here.
