I give the necessary pulse values to the gsm module to be open from the pwerkey pin. I also set the reset pin high. When I apply voltage to the module, the status led flashes. What does this flashing mean? What can I do to make it burn all the time? (I am using custom design)
- BG95M3 is 3 RAT module (CATM/GSM/NB) ,
Is the GSM module you are talking about bg95 module? - if the status LED is flashing ,it means that the module is running
- mode, it can be turned on by driving PWRKEY low for 500–1000 ms. It
for more detail , pls kindly download the below link:
