Hi everyone, I am a relatively new firmware developer and am especially new to working with cellular modems in general and Quectel in particular. Based on the AT command manual, I learned that responses of the modem are always of the form:
<CR><LF><response><CR><LF>
based on which I create a state machine to parse the results of AT command lines (image below) based on the assumption (from the manual) that responses will ALWAYS come enclosed within <CR><LF>.
State S0 is start, state S2 is where the <response> gets buffered and S4 is where parsing is finished. Please do not be confused by the ~ and ! - they’re just symbols I had used to denote CR and LF respectively in this diagram.
This seems to work fine for some commands but for others there are <CR><LF> in between that throw off the above state machine. For example the response to the ATI command is as follows:
[00:00:15.704,193] <inf> sb_at_parser: new data
0d 0a 51 75 65 63 74 65 6c 0d 0a 45 43 38 30 30 |..Quecte l..EC800
4d 0d 0a 52 65 76 69 73 69 6f 6e 3a 20 45 43 38 |M..Revis ion: EC8
30 30 4d 43 4e 47 42 52 30 36 41 30 34 4d 30 38 |00MCNGBR 06A04M08
0d 0a 0d 0a 4f 4b 0d 0a |....OK..
[00:00:15.704,223] <inf> sb_at_parser: Parse success.
[00:00:15.704,254] <inf> sb_at_parser: Payload
51 75 65 63 74 65 6c |Quectel
[00:00:15.704,254] <inf> sb_at_parser: Parse success.
[00:00:15.704,315] <inf> sb_at_parser: Payload
52 65 76 69 73 69 6f 6e 3a 20 45 43 38 30 30 4d |Revision : EC800M
43 4e 47 42 52 30 36 41 30 34 4d 30 38 |CNGBR06A 04M08
[00:00:15.704,345] <inf> sb_at_parser: Parse success.
[00:00:15.704,376] <inf> sb_at_parser: Payload
4f 4b |OK
As you can see a block of data, namely EC800M gets ignored by the state machine because it is not enclosed in <CR><LF> but the other sentences get captured by the state machine.
I have highlighted the parts that are captured by the state machine in { } brackets
0d 0a {51 75 65 63 74 65 6c} 0d 0a 45 43 38 30 30 |..{Quecte l}..EC800
4d 0d 0a {52 65 76 69 73 69 6f 6e 3a 20 45 43 38 |M..{Revis ion: EC8
30 30 4d 43 4e 47 42 52 30 36 41 30 34 4d 30 38} |00MCNGBR 06A04M08}
0d 0a 0d 0a {4f 4b} 0d 0a |....{OK}..
Clearly the bytes: 45 43 38 30 30 4d (correspoding to EC800M) are being ignored.
Am I doing something wrong? The state machine is clearly not capturing everything but I designed it based on the manual which says:
The AT or at prefix must be added at the beginning of each command line. Entering
<CR>will terminate a command line. Commands are usually followed by a response that includes
<CR><LF><response><CR><LF>. Throughout this document, only the response will be presented,<CR><LF>are omitted intentionally.
Any help is highly appreciated! Thank you.
