Ssl implimentation with the help of at commands in ec200u
  • ESP32-C3 MQTTS EC200U Example (SPIFFS Version - Merged)
  • This version uses the user’s robust loop and AT command functions,
  • combined with all the necessary SSL fixes.
  • *** FINAL FIX APPLIED ***
  • This version now FORCE-DELETES all old/conflicting certificates from
  • the modem’s UFS on boot to prevent SSL stack confusion.
  • It includes fixes for:
    1. Correct command order: Config SSL/MQTT before activating network.
    1. Force-deletes ALL old certs from modem on boot.
    1. Uses the full “UFS:” path for the certificate.
    1. Uses “seclevel 1” (Server auth only).
    1. Forces “sslversion 3” (TLS 1.2 only).
    1. Forces a specific modern cipher suite (0XC02F).
    1. Enables SNI (“sni”, 1).
    1. Ignores modem’s local time (“ignorelocaltime”, 1).
    1. Links MQTT to the correct PDP context (“pdpcid”, 1).
    1. Waits for the correct URCs (e.g., “+QMTOPEN: 0,0”).
    1. Removes the failing “clientid” command.
  • PLATFORMIO SPIFFS PREPARATION:
    1. Create a ‘data’ folder in your project’s root.
    1. Place ‘isrgroot.pem’ inside the ‘data’ folder.
    1. Run ‘pio run -t uploadfs’ to upload the file to the ESP32’s SPIFFS.
  • HARDWARE CONNECTIONS (ESP32-C3 ↔ EC200U):
    • ESP32 3.3V → EC200U VCC
    • ESP32 GND → EC200U GND
    • ESP32 TXD1 (19) → EC200U Main RX
    • ESP32 RXD1 (18) → EC200U Main TX
#include <Arduino.h> // Required for PlatformIO
#include <HardwareSerial.h> // Include for HardwareSerial communication
#include <string.h> // Include for strlen
#include “SPIFFS.h” // Include SPIFFS library
// — User Configuration —
// Modem communication pins and baud rate
#define MODEM_RX 18
#define MODEM_TX 19
#define MODEM_BAUD 115200
#define MStat 2 // Status LED
// APN Configuration
#define APN “”
// MQTT Broker Details
#define MQTT_SERVER “”
#define MQTT_PORT 8883
#define MQTT_USERNAME “”
#define MQTT_PASSWORD “”
#define MQTT_CLIENT_ID “esp32-c3-device-01” // MUST be unique
#define MQTT_TOPIC “test”
// Certificate file paths
#define CERT_FILENAME_ON_SPIFFS “/isrgroot.pem” // Path on ESP32
#define CERT_FILENAME_ON_MODEM “isrgroot.pem” // Filename on Modem
#define CERT_FULLPATH_ON_MODEM “UFS:isrgroot.pem” // Full path on Modem
#define SSL_CONTEXT_ID 0 // We’ll use SSL context 0
// Create a HardwareSerial instance for the modem
HardwareSerial modem(1);
// Global flag to track MQTT connection status
bool mqttConnected = false;
// — Utility Functions —
  • @brief Sends an AT command and waits for a specific expected response.
    String sendATCommand(String command, int timeout, String expectedResponse) {
    // Clear any existing serial data before sending
    while (modem.available()) {
    modem.read();
if (command != “”) {
modem.println(command);
String response = “”;
long startTime = millis();
Serial.print(">>> “);
Serial.println(command);
Serial.print(”<<< ");
while (millis() - startTime < timeout) {
if (modem.available()) {
char c = (char)modem.read();
response += c;
// Print the character that was just read and added to ‘response’
Serial.print(c);
  // Check for expected response only after reading
  if (expectedResponse != "" && response.indexOf(expectedResponse) != -1) {
    return response;
  if (response.indexOf("ERROR") != -1) {
    return response; // Return on error
Serial.println(); // Newline for clean output if timeout occurs
// If we just wanted to send, and didn’t timeout or error, return OK
if (expectedResponse == “” && response.indexOf(“ERROR”) == -1) return “OK”;
return response; // Return response (which may be a timeout)
  • @brief Waits for the PDP context to be fully active.
    bool waitForActivation(uint32_t timeout = 30000) {
    Serial.println(“\n[INFO] Waiting for PDP Context Activation (30s timeout)…”);
    String response = sendATCommand(“AT+QIACT?”, 2000, “+QIACT: 1,1,1”);
    if (response.indexOf(“+QIACT: 1,1,1”) != -1) {
    Serial.println(“[INFO] PDP Context is active.”);
    return true;
    Serial.println(“[INFO] Waiting… (PDP context not active yet)”);
    delay(2000);
    Serial.println(“[ERROR] PDP Context activation timed out!”);
    return false;
  • @brief Checks if a file exists on the modem’s UFS.
    bool checkFileOnModem(const char
    filename) {
    Serial.println(“\n[INFO] Checking for file on modem…”);
    String response = sendATCommand(“AT+QFLST”, 5000, “OK”);
if (response.indexOf(filename) != -1) {
Serial.println(“[INFO] File found in modem file list.”);
return true;
Serial.println(“[INFO] File not found in modem file list.”);
return false;
  • Reads a file from ESP32 SPIFFS and uploads it to the modem’s UFS.
    bool uploadFileToModem(const char
    spiffsFilename, const char* modemFilename) {
    Serial.println(“\n[INFO] Uploading file from SPIFFS to modem…”);
File file = SPIFFS.open(spiffsFilename, “r”);
if (!file) {
Serial.print("[ERROR] Failed to open file from SPIFFS: “);
Serial.println(spiffsFilename);
return false;
size_t fileSize = file.size();
Serial.print(”[INFO] File found on SPIFFS. Size: ");
Serial.println(fileSize);
String cmd = “AT+QFUPL="” + String(modemFilename) + “",” + String(fileSize) + “,100”;
if (sendATCommand(cmd, 5000, “CONNECT”).indexOf(“CONNECT”) == -1) {
Serial.println(“!! Cert upload failed: No CONNECT received.”);
file.close();
return false;
Serial.println(“[INFO] Modem is ready. Sending file data…”);
uint8_t buffer[256];
size_t bytesSent = 0;
while (bytesSent < fileSize) {
size_t bytesToRead = file.read(buffer, sizeof(buffer));
if (bytesToRead == 0) break; // End of file
modem.write(buffer, bytesToRead);
bytesSent += bytesToRead;
Serial.print(“.”);
Serial.println(“\n[INFO] File data sent.”);
file.close();
if (sendATCommand(“”, 10000, “OK”).indexOf(“OK”) != -1) {
Serial.println(“>> Cert Uploaded Successfully: " + String(modemFilename));
delay(1000); // Give filesystem time
return true;
} else {
Serial.println(”!! Cert upload failed: Modem did not confirm OK.");
return false;
// — MQTT and Connection Functions (MERGED & RE-ORDERED) —
  • Initializes the modem and checks SIM/Network.
    bool initAndCheckNetwork() {
    if (sendATCommand(“AT”, 2000, “OK”).indexOf(“OK”) == -1) {
    Serial.println(“\n[ERROR] Modem not ready.”);
    return false;
    Serial.println(“\n[INFO] Modem: OK.”);
sendATCommand(“ATE0”, 500, “OK”); // Disable echo
sendATCommand(“AT+CFUN=1”, 10000, “OK”); // Set full functionality
Serial.print(“[INFO] Checking SIM and Network…”);
if (sendATCommand(“AT+CPIN?”, 5000, “+CPIN: READY”).indexOf(“READY”) == -1) {
Serial.println(“\n[ERROR] SIM not ready (AT+CPIN?).”); return false;
if (sendATCommand(“AT+CSQ”, 1000, “+CSQ:”).indexOf(“+CSQ:”) == -1) {
Serial.println(“\n[ERROR] Failed to check signal quality (AT+CSQ).”); return false;
String regResponse = sendATCommand(“AT+CREG?”, 2000, “OK”);
if (regResponse.indexOf(“+CREG: 0,1”) == -1 && regResponse.indexOf(“+CREG: 0,5”) == -1) {
Serial.println(“\n[ERROR] Not registered on network (AT+CREG?).”); return false;
if (sendATCommand(“AT+CGATT=1”, 1000, “OK”).indexOf(“OK”) == -1) {
Serial.println(“\n[ERROR] Failed to attach to GPRS (AT+CGATT=1).”); return false;
Serial.println(“\n[INFO] SIM/Network Checks OK.”);
return true;
  • @brief Configures the modem’s SSL Context with all required settings.
    bool configureSSL() {
// *** NEW: FORCE-DELETE ALL OLD/CONFLICTING CERT FILES ***
Serial.println(“\n[INFO] Forcing deletion of old certificate file(s)…”);
sendATCommand(“AT+QFDEL="” + String(CERT_FULLPATH_ON_MODEM) + “"”, 5000, “”);
sendATCommand(“AT+QFDEL="UFS:ca.crt"”, 5000, “”);
sendATCommand(“AT+QFDEL="UFS:client.crt"”, 5000, “”);
sendATCommand(“AT+QFDEL="UFS:client.key"”, 5000, “”);
sendATCommand(“AT+QFDEL="UFS:isrg.pem"”, 5000, “”);
sendATCommand(“AT+QFDEL="UFS:isrgrootx1.pem"”, 5000, “”);
Serial.println(“[INFO] Old file cleanup complete.”);
Serial.println(“\n[INFO] Checking/Uploading Certificate…”);
// Check if file exists. If not, upload it.
// We use the FILENAME here, not the full path, for the check
if (!checkFileOnModem(CERT_FILENAME_ON_MODEM)) {
Serial.println(“[INFO] Certificate not found on modem, uploading…”);
// We use the FILENAME for the upload command
if (!uploadFileToModem(CERT_FILENAME_ON_SPIFFS, CERT_FILENAME_ON_MODEM)) {
Serial.println(“[ERROR] CRITICAL: Failed to upload certificate to modem!”);
return false;
} else {
Serial.println(“[INFO] Certificate file already exists on modem.”);
Serial.println(“\n[INFO] Configuring SSL Context…”);
// Force TLS 1.2
if (sendATCommand(“AT+QSSLCFG="sslversion",” + String(SSL_CONTEXT_ID) + “,3”, 1000, “OK”).indexOf(“OK”) == -1) return false;
// Force modern Cipher
if (sendATCommand(“AT+QSSLCFG="ciphersuite",” + String(SSL_CONTEXT_ID) + “,0XC02F”, 1000, “OK”).indexOf(“OK”) == -1) return false;
// Server Auth Only
if (sendATCommand(“AT+QSSLCFG="seclevel",” + String(SSL_CONTEXT_ID) + “,1”, 1000, “OK”).indexOf(“OK”) == -1) return false;
// Set CA cert path (using the FULL UFS path)
if (sendATCommand(“AT+QSSLCFG="cacert",” + String(SSL_CONTEXT_ID) + “,"” + String(CERT_FULLPATH_ON_MODEM) + “"”, 1000, “OK”).indexOf(“OK”) == -1) return false;
// Ignore modem clock
if (sendATCommand(“AT+QSSLCFG="ignorelocaltime",” + String(SSL_CONTEXT_ID) + “,1”, 1000, “OK”).indexOf(“OK”) == -1) return false;
// Enable SNI
if (sendATCommand(“AT+QSSLCFG="sni",” + String(SSL_CONTEXT_ID) + “,1”, 1000, “OK”).indexOf(“OK”) == -1) return false;
Serial.println(“[INFO] SSL Context Configured.”);
return true;
  • @brief Configures the MQTT instance 0 to use the SSL context.
    bool configureMQTT() {
    Serial.println(“\n[INFO] Configuring MQTT for SSL…”);
    // Link to PDP context 1
    if (sendATCommand(“AT+QMTCFG="pdpcid",0,1”, 1000, “OK”).indexOf(“OK”) == -1) return false;
    // Enable SSL on MQTT instance 0, link to SSL Context 0
    if (sendATCommand(“AT+QMTCFG="ssl",0,1,” + String(SSL_CONTEXT_ID), 1000, “OK”).indexOf(“OK”) == -1) return false;
    // Use MQTT 3.1.1
    if (sendATCommand(“AT+QMTCFG="version",0,4”, 1000, “OK”).indexOf(“OK”) == -1) return false;
    Serial.println(“[INFO] MQTT Configured for SSL.”);
    return true;
  • @brief Activates the network data connection (PDP Context).
    bool activateNetwork() {
    Serial.print(“[INFO] Deactivating old PDP context (AT+QIDEACT=1)…”);
    sendATCommand(“AT+QIDEACT=1”, 5000, “”); // We don’t care about the response
    Serial.println(“Done.”);
String apnCommand = “AT+QICSGP=1,1,"” + String(APN) + “","","",0”;
Serial.print(“[INFO] Setting APN…”);
if (sendATCommand(apnCommand, 5000, “OK”).indexOf(“OK”) == -1) {
Serial.println(“\n[ERROR] Failed to set APN (AT+QICSGP).”);
return false;
Serial.println(“\n[INFO] APN Set.”);
Serial.print(“[INFO] Connecting to GPRS/LTE…”);
if (sendATCommand(“AT+QIACT=1”, 30000, “OK”).indexOf(“OK”) == -1) {
Serial.println(“\n[ERROR] Failed to connect to GPRS/LTE. Check SIM/APN.”);
return false;
Serial.println(“\n[INFO] Connected to GPRS/LTE.”);
if (!waitForActivation()) {
return false; // Timeout waiting for IP
return true;
  • @brief Main connection function, calls helpers in the correct order.
    bool connectModemAndMQTT() {
// This is the new, “forum-approved” order of operations
if (!initAndCheckNetwork()) return false;
if (!configureSSL()) return false; // Configure SSL before network
if (!configureMQTT()) return false; // Configure MQTT before network
if (!activateNetwork()) return false; // Then activate the network
// — All configs are done, now try to connect —
// Open MQTT Network Connection (QMTOPEN)
Serial.print(“[INFO] Connecting to MQTT Broker…”);
String openCommand = “AT+QMTOPEN=0,"” + String(MQTT_SERVER) + “",” + String(MQTT_PORT);
// Wait for +QMTOPEN: 0,0 (Success)
if (sendATCommand(openCommand, 15000, “+QMTOPEN: 0,0”).indexOf(“+QMTOPEN: 0,0”) == -1) {
Serial.println(“\n[ERROR] Failed to open network connection. Check SSL config.”);
return false;
Serial.println(“\n[INFO] MQTT Network Open.”);
// Connect to MQTT Broker (QMTCONN)
Serial.print(“[INFO] Logging into MQTT Broker…”);
String connCommand = “AT+QMTCONN=0,"” + String(MQTT_CLIENT_ID) + “","” + String(MQTT_USERNAME) + “","” + String(MQTT_PASSWORD) + “"”;
// Wait for +QMTCONN: 0,0,0 (Success)
if (sendATCommand(connCommand, 15000, “+QMTCONN: 0,0,0”).indexOf(“+QMTCONN: 0,0,0”) == -1) {
Serial.println(“\n[ERROR] Failed to connect to MQTT broker. Check credentials.”);
sendATCommand(“AT+QMTCLOSE=0”, 2000, “OK”);
return false;
Serial.println(“\n[INFO] MQTT Connected Successfully!”);
return true;
  • @brief Publishes a message to the MQTT topic.
    bool mqttPublish(const char
    payload) {
    static int messageId = 1;
Serial.print(“[INFO] Publishing message: '”);
Serial.print(payload);
Serial.print("’ to topic: ");
Serial.println(MQTT_TOPIC);
String pubCommand = “AT+QMTPUB=0,” + String(messageId++) + “,0,0,"” + String(MQTT_TOPIC) + “"”;
// 1. Send the AT+QMTPUB command and wait for the “>” prompt
if (sendATCommand(pubCommand, 3000, “>”).indexOf(“>”) == -1) {
Serial.println(“\n[ERROR] Failed to publish (did not get > prompt).”);
return false;
// 2. Send the payload and the Ctrl+Z character
modem.print(payload);
modem.write(0x1A); // Send Ctrl+Z (ASCII 26) to signal end of data
Serial.print("<<< “); Serial.print(payload); Serial.print(” + [Ctrl+Z] … ");
// 4. Wait for the final response from the modem
// We expect +QMTPUB: 0, (messageId-1), 0 (for QoS 0)
String expectedResponse = “+QMTPUB: 0,” + String(messageId - 1) + “,0”;
if (sendATCommand(“”, 5000, expectedResponse).indexOf(expectedResponse) != -1) {
Serial.println(“\n[INFO] Publish successful!”);
digitalWrite(MStat, HIGH);
delay(100);
digitalWrite(MStat, LOW);
return true;
} else {
Serial.println(“\n[ERROR] Message publish failed.”);
return false;
// — Setup and Loop —
void setup() {
Serial.begin(115200);
pinMode(MStat, OUTPUT);
// Initialize the HardwareSerial for the modem
modem.begin(MODEM_BAUD, SERIAL_8N1, MODEM_RX, MODEM_TX);
Serial.println(“— EC200U MQTTS Publisher Start (Merged Code) —”);
// *** NEW: Initialize SPIFFS ***
if (!SPIFFS.begin(true)) {
Serial.println(“[ERROR] SPIFFS Mount Failed! Halting.”);
while(1) delay(1000); // Halt if SPIFFS fails
} else {
Serial.println(“[INFO] SPIFFS Mounted.”);
// Establish connection in setup
mqttConnected = connectModemAndMQTT();
if (!mqttConnected) {
Serial.println(“\n[FATAL] Initial connection failed. Loop will attempt reconnect.”);
void loop() {
static unsigned long lastPublishTime = 0;
const long publishInterval = 10000; // Publish every 10 seconds
// Read and print any unsolicited messages (URCs)
Serial.print((char)modem.read());
// If not connected, try to reconnect
Serial.println(“\n[WARN] Attempting full modem and MQTT reconnect…”);
// Give the modem a moment if it failed recently
delay(2000);
// If connected, publish the message periodically
if (mqttConnected && millis() - lastPublishTime >= publishInterval) {
lastPublishTime = millis();
if (!mqttPublish(“hello”)) {
// If publish fails, assume connection is lost and trigger a full reconnect
output _
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x90c
load:0x403ce710,len:0x2624
entry 0x403cc710
AT
[INFO] Modem: OK.
ATE0
OK>>> AT+CFUN=1
OK[INFO] Checking SIM and Network…>>> AT+CPIN?
+CPIN: READY>>> AT+CSQ
+CSQ:>>> AT+CREG?
+CREG: 0,1
OK>>> AT+CGATT=1
AT+QFDEL=“UFS:isrgroot.pem”
AT+QFDEL=“UFS:ca.crt”
+CME ERROR>>> AT+QFDEL=“UFS:client.crt”
+CME ERROR>>> AT+QFDEL=“UFS:client.key”
+CME ERROR>>> AT+QFDEL=“UFS:isrg.pem”
+CME ERROR>>> AT+QFDEL=“UFS:isrgrootx1.pem”
+CME ERROR[INFO] Old file cleanup complete.
AT+QFLST
+QFLST: “UFS:boot”,15004
+QFLST: “UFS:firm”,243616
+QFLST: “UFS:gnss_data”,4636
+QFLST: “UFS:gnss_loca”,47
+QFLST: “UFS:gnss_time”,21
OK[INFO] File not found in modem file list.
[INFO] File found on SPIFFS. Size: 1939
AT+QFUPL=“isrgroot.pem”,1939,100
CONNECT[INFO] Modem is ready. Sending file data…
<<< +QFUPL: 1939,4f64
OK>> Cert Uploaded Successfully: isrgroot.pem
AT+QSSLCFG=“sslversion”,0,3
OK>>> AT+QSSLCFG=“ciphersuite”,0,0XC02F
OK>>> AT+QSSLCFG=“seclevel”,0,1
OK>>> AT+QSSLCFG=“cacert”,0,“UFS:isrgroot.pem”
OK>>> AT+QSSLCFG=“ignorelocaltime”,0,1
OK>>> AT+QSSLCFG=“sni”,0,1
OK[INFO] SSL Context Configured.
AT+QMTCFG=“pdpcid”,0,1
OK>>> AT+QMTCFG=“ssl”,0,1,0
OK>>> AT+QMTCFG=“version”,0,4
OK[INFO] MQTT Configured for SSL.
[INFO] Deactivating old PDP context (AT+QIDEACT=1)…>>> AT+QIDEACT=1
Done.
[INFO] Setting APN…>>> AT+QICSGP=1,1,“www”,“”,“”,0
[INFO] APN Set.
[INFO] Connecting to GPRS/LTE…>>> AT+QIACT=1
AT+QIACT?
+QIACT: 1,1,1[INFO] PDP Context is active.
[INFO] Connecting to MQTT Broker…>>> AT+QMTOPEN=0,“”,8883
+QMTOPEN: 0,5
AT
[INFO] Modem: OK.
ATE0
OK>>> AT+CFUN=1
+CSQ:>>> AT+CREG?
+CREG: 0,1
OK>>> AT+CGATT=1
again and again +QMTOPEN: 0,5
if any requirement is there let me know
Hi Vinayak,
I am sorry, may I know if there is any issue or any information needed?
Regards,
Fazrul Redzuan
very late reply , thankyou for asking , i am able to do that no issue now.
