Dear Quectel representatives!
When will the problem with spontaneous drops of the LTE interface in Mikrotik Chateau LTE12 with the EG12-EA module be finally solved? Now it has firmware revision EG12EAPAR01A11M4G, but the problem has not disappeared.
The problem occurs with different SIM cards, different mobile operators.
09:04:32 lte,async,raw lte1: rcvd +QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,250,99,BC6A607,333,1301,3,4,4,28A,-92,-12,-62,17,-,150,-
09:04:32 lte,async,raw lte1: sent AT+QCAINFO
09:04:32 lte,async,raw lte1: rcvd +QCAINFO: “pcc”,1301,75,“LTE BAND 3”,1,333,-91,-12,-58,15
09:04:32 lte,async,raw lte1: rcvd +QCAINFO: “scc”,3300,50,“LTE BAND 7”,1,999,-118,-15,-93,0
09:04:32 lte,async,raw lte1: rcvd DL
09:04:32 lte,async,raw lte1: sent AT+QXPOWER
09:04:32 lte,async,raw lte1: rcvd +QXPOWER: -80,210,-32768,50
09:04:32 lte,async,raw lte1: sent AT+QNETINFO=“cmr”
09:04:32 lte,async,raw lte1: rcvd +QNETINFO: “cmr”,9,3,1,2
09:04:32 lte,async,raw lte1: sent AT+QRSRP
09:04:32 lte,async,raw lte1: rcvd +QRSRP: -94,-90,-140,-140
09:04:32 lte,async,raw lte1: sent AT+QNWCFG=“lte_rx_power”
09:04:32 lte,async,raw lte1: rcvd +QNWCFG: -61,-57,0,0
09:04:35 lte,packet,raw lte1 mbim: wdm >>> recv #0
09:04:35 lte,packet,raw 07000080 48000000 00000000 01000000
09:04:35 lte,packet,raw 00000000 a289cc33 bcbb8b4f b6b0133e
09:04:35 lte,packet,raw c2aae6df 0a000000 1c000000 00000000
09:04:35 lte,packet,raw 01000000 00000000 00000000 00000000
09:04:35 lte,packet,raw 00000000 00000000
09:04:35 lte,debug lte1 mbim: >>> N service: connect, command: packet service
09:04:35 lte,packet lte1 mbim: status data:
09:04:35 lte,packet 00000000 01000000 00000000 00000000
09:04:35 lte,packet 00000000 00000000 00000000
09:04:35 lte,debug lte1 mbim: packet service: attaching class: 0 nwe:
09:04:35 lte,debug lte1 mbim: state 16=>14
09:04:35 lte,account lte1 session: 89546s 5303094716/1280192518 bytes 4275272/1983497 packets
09:04:35 interface,info lte1 link down
But at this time, the modem correctly responds to the AT + QPING command
[admin@MikroTik] > interface lte at-chat lte1 input=“AT+QPING=1,"netfiles.ru"”
output: OK
Then, after a few minutes, the LTE interface spontaneously link up and Internet access appears again.
Technical support from Mikrotik could not establish the cause of the fall of the LTE interface.
