Hello team, I have a problem with my EC25-AU Mini Pcie because when trying it with different hardware/sim it always shows the same message “SIM is not ready”.
log:
[2023-07-02 19:27:23:427_S:] AT+CPIN?
[2023-07-02 19:27:23:491_R:] AT+CPIN?
[2023-07-02 19:27:23:491_R:] +CME ERROR: SIM not inserted
[2023-07-02 19:34:21:646_R:] AT+QSIMDET=?
[2023-07-02 19:34:21:646_R:] +QSIMDET: (0,1),(0,1)
[2023-07-02 19:36:46:150_R:] AT+QSIMSTAT=?
[2023-07-02 19:36:46:150_R:] +QSIMSTAT: (0,1)
I have tried to use the following at commands but it doesn’t work(reset)
ATZ.
AT+CFUN
AT&F
Please help me.
calef01:
AT+QSIMDET=?
calef01:
AT+QSIMDET=?
This is the test syntax of these two commands. They return lists of the supported values, and not the currently set values.
You need the read syntax. That’s with a trailing ? and not =?
AT+QSIMDET?
AT+QSIMSTAT?
Hi Snowgum, the response after execution :
[2023-07-02 20:46:35:401_S:] AT+QSIMDET?
[2023-07-02 20:46:35:460_R:] AT+QSIMDET?
[2023-07-02 20:46:35:460_R:] +QSIMDET: 1,0
[2023-07-02 20:46:35:460_R:] OK
[2023-07-02 20:47:06:698_S:] AT+QSIMSTAT?
[2023-07-02 20:47:06:754_R:] AT+QSIMSTAT?
[2023-07-02 20:47:06:754_R:] +QSIMSTAT: 1,0
[2023-07-02 20:47:06:754_R:] OK
These are not the default settings, as detailed in the EC2x&EC9x&EG2x-G&EM05 Series AT Commands Manual .
Default values are the underlined ones in AT command manuals.
Have you tried running with the default settings? That’s:
AT+QSIMDET=0,0
AT+QSIMSTAT=0
