eyau
July 29, 2020, 8:45am
1
I’m using EG-25G modem. I’m trying to send SMS with PDU mode. But i always got “CMS ERROR: 304” after entering
at+cmgf=0
at+cmgf=0
at+cmgs=26
at+cmgs=26
0011000881214365870000A70FF4F29C0E6A97E7F3F0B90C8A3500
^Z11000881214365870000A70FF4F29C0E6A97E7F3F0B90C8A3500
+CMS ERROR: 304
I can send the SMS with text mode successfully. Could you please advise ?
Thanks.
eyau
July 29, 2020, 9:55am
2
Problem solved after using a Linux-based terminal. It seems Putty added another character before the ‘ctrl-z’ character when I press Ctrl-Z, causing the modem to return error.
Kyson
July 29, 2020, 11:15am
3
Ok, got it. Thanks for your updating. Thanks!
hello dear, I have the same problem may I know which terminal did you use ?
eyau
February 14, 2022, 8:47am
5
I’m using ‘minicom’ in Linux to get this working.
snowgum
February 14, 2022, 8:52am
6
Flying_Drone:
Your Ctrl-Z character needs to be on the same line as the PDU. There must be no new-line character between them.
eyau
February 14, 2022, 8:53am
7
Alternately, you can use ‘TeraTerm’
