SMART-EVB v1.3 with SC20-AU - prebuilt images
Where can I download the prebuilt Android and Linux images and firmware files for the SC20-AU module with the support for the SMART-EVB v1.3 board?
Please also suggest the relevant documentation with the instructions on how to load those firmware and OS images into the module.
Dear, customers:
The documents and firmware are on Quectel driver.
Do you have the account?
Do you mean the download-zone ?
I have an account on the main Quectel website and this forum only.
Dear, customers:
I mean: https://drive2.quectel.com/
If you don’t have the account, what’s the current firmware version on your module?
Please also share your email here
My email address: sergoserg@gmail.com
QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.2.C2-00037
IMAGE_VARIANT_STRING=DAASANAZA
OEM_IMAGE_VERSION_STRING=administrator-p
The OS fails to fully load:
[ 5.734699] msm_hsusb msm_hsusb: CI13XXX_CONTROLLER_RESET_EVENT received
[ 5.734718] msm_hsusb msm_hsusb: CI13XXX_CONTROLLER_CONNECT_EVENT received
[ 6.074683] mmc0: eMMC FW versi²rºÂ¢²êmmc0: CMDQ supported: depth: 32
[ 6.081647] mmc0: cache barrier support 1 flush policy 1
[ 6.087061] Waiting for root device /dev/mmcblk0p21…
[ 6.107601] mmc0: new HS200 MMC card at address 0001
[ 6.112214] mmc0: -524: cmdq: unable to set-up
[ 6.116383] mmcblk0: mmc0:0001 H8G4a2 7.28 GiB
[ 6.120975] mmcblk0rpmb: mmc0:0001 H8G4a2 partition 3 4.00 MiB
[ 6.130513] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36
[ 6.162621] msm8952-asoc-wcd 7702000.sound: default codec configured
[ 6.171391] msm8952-asoc-wcd 7702000.sound: ASoC: CODEC DAI cajon_vifeedback not registered
[ 6.178754] msm8952-asoc-wcd 7702000.sound: snd_soc_register_card failed (-517)
[ 6.202001] EXT4-fs (mmcblk0p21): couldn’t mount as ext3 due to feature incompatibilities
[ 6.209711] EXT4-fs (mmcblk0p21): couldn’t mount as ext2 due to feature incompatibilities
[ 6.222678] EXT4-fs (mmcblk0p21): mounted filesystem with ordered data mode. Opts: (null)
[ 6.229865] VFS: Mounted root (ext4 filesystem) readonly on device 179:21.
[ 6.237280] devtmpfs: error mounting -2
[ 6.242536] Freeing unused kernel memory: 812K
[ 6.246395] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 6.259050] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.18.71 #1
[ 6.265056] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.272773] [] (show_stack) from [] (dump_stack+0x74/0x90)
[ 6.279975] [] (dump_stack) from [] (panic+0x114/0x39c)
[ 6.286919] [] (panic) from [] (kernel_init+0xc8/0x108)
[ 6.293862] [] (kernel_init) from [] (ret_from_fork+0x14/0x3c)
[ 6.301418] CPU0: stopping
[ 6.304101] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.18.71 #1
[ 6.310099] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.317822] [] (show_stack) from [] (dump_stack+0x74/0x90)
[ 6.325027] [] (dump_stack) from [] (handle_IPI+0x270/0x3ac)
[ 6.332404] [] (handle_IPI) from [] (gic_handle_irq+0x74/0x7c)
[ 6.339957] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x90)
[ 6.347416] Exception stack(0xc1401ec8 to 0xc1401f10)
[ 6.352453] 1ec0: 00000068 00000000 0000a122 000003e8 00000000 eb89d010
[ 6.360614] 1ee0: eb4b8010 eddee570 8d4fdf3b 83126e97 01424435 00000000 00000000 c1401f18
[ 6.368771] 1f00: c01824a8 c0869208 00000113 ffffffff
[ 6.373813] [] (__irq_svc) from [] (lpm_cpuidle_enter+0x5a0/0x6f4)
[ 6.381713] [] (lpm_cpuidle_enter) from [] (cpuidle_enter_state+0xd8/0x2ec)
[ 6.390393] [] (cpuidle_enter_state) from [] (cpu_startup_entry+0x334/0x3ac)
[ 6.399161] [] (cpu_startup_entry) from [] (start_kernel+0x3a8/0x420)
[ 6.407312] CPU3: stopping
[ 6.410005] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.18.71 #1
[ 6.416001] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.423726] [] (show_stack) from [] (dump_stack+0x74/0x90)
[ 6.430928] [] (dump_stack) from [] (handle_IPI+0x270/0x3ac)
[ 6.438306] [] (handle_IPI) from [] (gic_handle_irq+0x74/0x7c)
[ 6.445859] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x90)
[ 6.453318] Exception stack(0xed653f00 to 0xed653f48)
[ 6.458358] 3f00: 000000b1 00000000 0000fab2 000003e8 00000000 eb89d010 eb4b8010 ede0f570
[ 6.466518] 3f20: 8d4fdf3b 83126e97 01f5645b 00000000 00000000 ed653f50 c01824a8 c0869208
[ 6.474672] 3f40: 00000113 ffffffff
[ 6.478152] [] (__irq_svc) from [] (lpm_cpuidle_enter+0x5a0/0x6f4)
[ 6.486051] [] (lpm_cpuidle_enter) from [] (cpuidle_enter_state+0xd8/0x2ec)
[ 6.494732] [] (cpuidle_enter_state) from [] (cpu_startup_entry+0x334/0x3ac)
[ 6.503497] [] (cpu_startup_entry) from [<801007cc>] (0x801007cc)
[ 6.510437] CPU1: stopping
[ 6.513129] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.18.71 #1
[ 6.519126] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.526850] [] (show_stack) from [] (dump_stack+0x74/0x90)
[ 6.534053] [] (dump_stack) from [] (handle_IPI+0x270/0x3ac)
[ 6.541431] [] (handle_IPI) from [] (gic_handle_irq+0x74/0x7c)
[ 6.548984] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x90)
[ 6.556442] Exception stack(0xed64ff00 to 0xed64ff48)
[ 6.561483] ff00: 0000000b 00000000 0000c831 000003e8 00000000 eb89d010 eb4b8010 eddf9570
[ 6.569643] ff20: 8d4fdf3b 83126e97 01906206 00000000 00000000 ed64ff50 c01824a8 c0869208
[ 6.577797] ff40: 00000013 ffffffff
[ 6.581276] [] (__irq_svc) from [] (lpm_cpuidle_enter+0x5a0/0x6f4)
[ 6.589177] [] (lpm_cpuidle_enter) from [] (cpuidle_enter_state+0xd8/0x2ec)
[ 6.597856] [] (cpuidle_enter_state) from [] (cpu_startup_entry+0x334/0x3ac)
[ 6.606621] [] (cpu_startup_entry) from [<801007cc>] (0x801007cc)
[ 6.613567] msm_bus_panic_callback: fab-bimc: sleep max_ib: 400000000: client-name: sdhc1
[ 6.621722] msm_bus_panic_callback: fab-bimc: active max_ib: 4263510016: client-name: soc:qcom,cpubw
[ 6.630836] msm_bus_panic_callback: fab-bimc: sleep max_ab: 335544320: client-name: mdp3
[ 6.638908] msm_bus_panic_callback: fab-bimc: active max_ab: 335544320: client-name: mdp3
[ 6.647069] msm_bus_panic_callback: fab-pcnoc: sleep max_ib: 400000000: client-name: sdhc1
[ 6.655315] msm_bus_panic_callback: fab-pcnoc: active max_ib: 400000000: client-name: sdhc1
[ 6.663649] msm_bus_panic_callback: fab-pcnoc: sleep max_ab: 130718000: client-name: sdhc1
[ 6.671894] msm_bus_panic_callback: fab-pcnoc: active max_ab: 130718000: client-name: sdhc1
[ 6.680228] msm_bus_panic_callback: fab-snoc: sleep max_ib: 400000000: client-name: sdhc1
[ 6.688387] msm_bus_panic_callback: fab-snoc: active max_ib: 400000000: client-name: sdhc1
[ 6.696634] msm_bus_panic_callback: fab-snoc: sleep max_ab: 335544320: client-name: mdp3
[ 6.704707] msm_bus_panic_callback: fab-snoc: active max_ab: 335544320: client-name: mdp3
[ 6.712867] msm_bus_panic_callback: fab-snoc-mm: sleep max_ib: 335544320: client-name: mdp3
[ 6.721200] msm_bus_panic_callback: fab-snoc-mm: active max_ib: 335544320: client-name: mdp3
[ 6.729620] msm_bus_panic_callback: fab-snoc-mm: sleep max_ab: 335544320: client-name: mdp3
[ 6.737954] msm_bus_panic_callback: fab-snoc-mm: active max_ab: 335544320: client-name: mdp3
[ 7.946524] Rebooting in 5 seconds..
[ 12.948916] Going down for restart now
[ 12.952476] Causing a watchdog bite!
There are many Android versions, from Android 5-8,which Android version is used?
Unfortunately, I cannot determine the Android version because the system fails to boot due to a corrupted root filesystem (see the an excerpt from the boot log above).
The only information I can obtain from the boot chain is:
  • QC_IMAGE_VERSION_STRING: BOOT.BF.3.1.2.C2-00037
  • IMAGE_VARIANT_STRING: DAASANAZA
  • OEM_IMAGE_VERSION_STRING: administrator-p
Could you please identify the corresponding Android version for this firmware branch and provide the **matching full SC20-AU firmware package?
If multiple Android versions exist for SC20-AU, please provide the recommended or latest stable Android firmware compatible with this module and EVB.
Please provide the IMEI1 number
Sure, here it is:
869196030719120
Any update on the firmware & OS image package?
