Simultaneous Multiple PDP context
for our client we have to project an IoT solution with 2 PDP simultaneous context.
We need one modem which can manage:
  • IP1 with APN 1
  • IP2 with APN 2
Communication with both IP need to be simultaneous. Is this possible with a single SIM?
Hi There,
Yes, in general this is possible with a single SIM, provided that the modem, firmware, and network/operator all support multiple PDP contexts simultaneously.
In this case, the modem would need to support two active PDP contexts at the same time, for example:
  • PDP context 1 → APN 1 → IP1
  • PDP context 2 → APN 2 → IP2
Both data sessions can then run in parallel.
However, there are a few points that need to be confirmed:
  1. Module capability
    Not all modems support simultaneous active PDP contexts for user data.
  2. Network/operator support
    Some operators allow multiple PDP contexts on one SIM, while others may restrict this behavior.
  3. Application / protocol handling
    The software must be able to bind each connection to the correct PDP context.
Yes, it can be possible with a single SIM, but it depends on the specific module and operator support.
