Simultaneous MQTTS and TLS over TCP connexions
I am currently using the EG25-G LTE module, and I am having some issues running a MQTTS and TLS over TCP connexions simultaneously. So far, I tried using two differents PDP contexts, two differents SSL contexts, without any success. As a result, sending data to the TCP socket closes the MQTTS connexion (+QMTSTAT: 0,1). Is this a limitation or should I be able to do it ?
Regards,
Julien.
hi ,
Sorry for the late reply.
May I ask if further support is needed for this issue?
Could you please tell me if the MQTT and TCP protocols you are using are both internal protocols of the module?
