SimLock 1 No SIM Error on RM500Q-AE for T-mobile R15
I kept having issues to where I’ll ping out, whether I’m using ethernet or usb 3.0 connection, thats not the issue, its when the modem restarts on its own using watchdog, it doesnt always fully detect my sim card, so I would have to restart my whole router just to get my modem to work again. Its been like this for 6 months and its getting very annoying. I kept asking for any latest update for the modem with no response and apparently its more complicated then I first thought. So heres what i have here,
Sat Oct 19 08:15:43 2024 : Check Connection 1 Normal Exit
Sat Oct 19 08:49:50 2024 : QMI Connect Stopping network wan1
Sat Oct 19 08:49:50 2024 : usb-modeswitch Remove 2-1
Sat Oct 19 08:49:50 2024 : usb-modeswitch Device 2-1
Sat Oct 19 08:49:50 2024 : usb-modeswitch 1 Add : 2-1: Manufacturer=Quectel Product=RM500Q-AE Serial=52f531b0 2c7c 0800
Sat Oct 19 08:49:50 2024 : usb-modeswitch 1 *****************************************************************
Sat Oct 19 08:49:51 2024 : usb-modeswitch 1 *
Sat Oct 19 08:49:51 2024 : usb-modeswitch 1 * Start of Modem Detection and Connection Information
Sat Oct 19 08:49:51 2024 : usb-modeswitch 1 * Product=RM500Q-AE 2c7c 0800
Sat Oct 19 08:49:51 2024 : usb-modeswitch 1 *****************************************************************
Sat Oct 19 08:49:51 2024 : usb-modeswitch *****************************************************************
Sat Oct 19 08:49:51 2024 : usb-modeswitch 1 Found Modem at 2-1 in Cfg#= 1 from 1 available
Sat Oct 19 08:49:51 2024 : usb-modeswitch * Remove : 2-1 : Modem 1
Sat Oct 19 08:49:51 2024 : usb-modeswitch 1 * Device at 2-1 does not have a switch data file
Sat Oct 19 08:49:51 2024 : usb-modeswitch * No Modems present
Sat Oct 19 08:50:01 2024 : usb-modeswitch 1 *****************************************************************
Sat Oct 19 08:50:01 2024 : usb-modeswitch 1 * Modem at 2-1 switched to : 2c7c:0800
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Number Interfaces w/drivers : 6
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Driver Name : 0 option
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Driver Name : 1
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Driver Name : 2 option
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Driver Name : 3 option
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Driver Name : 4 qmi_wwan
Sat Oct 19 08:50:01 2024 : Protofind 2c7c/0800 Driver Name : 6
Sat Oct 19 08:50:01 2024 : usb-modeswitch 1 * ProtoFind returns : 2
Sat Oct 19 08:50:01 2024 : usb-modeswitch 1 Found Modem 1
Sat Oct 19 08:50:01 2024 : usb-modeswitch 1 Connecting a QMI Modem
Sat Oct 19 08:50:02 2024 : Create Connection 1 Start Connection
Sat Oct 19 08:50:02 2024 : Create Connection 1 Modem 1 is a parent of ttyUSB0 ttyUSB1 ttyUSB2
Sat Oct 19 08:50:02 2024 : PreConnect 1 Running PreConnect script
Sat Oct 19 08:50:29 2024 : SimLock 1 No SIM
You need to look at this from the modem perspective, what you show is a result of some 3rd-party connection script that has nothing to do with Quectel.
Check with at+cpin? for example.
at+cpin?
+CPIN: READY
This means that the SIM card is unlocked and there are currently no problems or errors with accessing it.
Quectel RM500Q-AE do not need to use the usb modeswitch.
