Sim Card not Inserted issue on few Sim cards
Hi, following a related but distinct SIM issue on the same module (EG912U-GL) that may share underlying cause with what’s reported here, posting in case it’s useful context, or please redirect me to a more appropriate thread if this isn’t the right place.
Module: EG912U-GL, firmware EG912UGLAAR03A18M08
Symptom: AT+CPIN? returns +CPIN: READY with one specific SIM (Zong, Pakistan), but returns +CME ERROR: 10 (“SIM not inserted”) with every other physical nano-SIM we’ve tested, two other Pakistani carriers and two UK IoT SIM providers — reproduced identically across two separate assembled boards.
Diagnostics:
AT+QSIMDET=1,0 / 1,1 : both accepted (OK), no change in outcome
AT+QSIMVOLT=0/1/2 : returns CME ERROR: 58 on all values, appears unsupported on this firmware
Oscilloscope capture of SIM_RST/SIM_DATA during power-up: the working SIM shows initial toggling settling into a stable high state (~3.3V, successful ATR); the failing SIM shows similar initial activity but drops to ~240–320mV and stays low, consistent with the module attempting one voltage-class recognition, failing, and powering down the interface (matches the behavior described in Quectel’s own “SIM card cannot be recognized” troubleshooting guide)
Cross-checked the same “failing” SIM on a different modem chipset (SIMCom A7670E) which registers and initializes normally there, confirming the SIM card itself isn’t defective
Question: Is there a known ATR/voltage-class negotiation limitation on this firmware build, and is there an alternate way to force SIM voltage class given AT+QSIMVOLT isn’t accepted? Does the issue is with Sim-lock for specific regions/companies?
Hi @usamamughal8345
This is not a SIM/operator lock. The AT+QSIMVOLT command is unsupported on this module series; the PMU relies entirely on automatic voltage-class negotiation.
The oscilloscope capture where the voltage on SIM_RST/SIM_DATA drops to ~240–320mV, is the standard behavior of the PMU when ATR negotiation fails.
Troubleshooting step:
  1. Please try disabling SIM hot-swap function by executing AT+QSIMDET=0,0 then reboot the module to check if it resolves the issue.
  2. Could you please confirm whether the above testing was performed on your custom board or on a Quectel EVB?
  3. Ensure that, Added a 10kΩ to 20kΩ pull-up resistor on the SIM_DATA line.
  4. Keep trace lengths short and ensure any ESD protection diodes have a parasitic capacitance under 10pF.
  5. Place a 100nF to 1µF decoupling capacitor close to the SIM holder’s V_SIM pin.
  6. There is no indication that this issue is caused by regional or corporate SIM locks. You can check the SIM lock status by executing AT+CLCK=“SC”,2
Thanks for the detailed suggestions. Update on each:
AT+QSIMDET=0,0 (full hot-swap disable) tested: accepted (OK), but SIM detection still fails identically after reset.
Confirmed: all testing has been on our custom board, not a Quectel EVB.
AT+CLCK=“SC”,2 could not complete: returned +CME ERROR: 13 (“SIM failure”) rather than a lock status. The same error appeared on AT+QCCID. This happens consistently with the failing SIM, while the working SIM (different carrier) returns these cleanly.
3. We haven’t yet added the 10-20kΩ pull-up on SIM_DATA, could you clarify which side of the line (module-side vs. holder-side) and confirm the exact target voltage rail (1.8V vs 3.3V) for that pull-up on the EG912U-GL specifically?
4. It has a 100nF decoupling capacitor close to the SIM holder’s V_SIM pin.
Separately: is there any significance to CME ERROR: 13 (SIM failure) appearing instead of the usual CME ERROR: 10 (SIM not inserted) on some attempts with the same card? Wondering if this points to something more specific than a generic detection failure.
