I posted a question of SIM card detection problem in EC21-AU module. It always reports error “SIM Card Not inserted”. Unfortunately, nobody replied any solution of the question. Maybe there are similar questions in the forum. The answers cannot get help for my case anyway.
By checking the PCB layout, the traces of USIM_DATA and USIM_CLK are very close in the layout. Will it be a cause of SIM detection failed ?
1)Please try to replace another SIM card, if the output is the same alarm, it may be caused by your PCB
2)You can also solder the SIM pin of the EC21 out and connect to the SIM card holder and try to read if the card is working
I have replaced by another SIM card. It is the same. I did solder the SIM pins of the EC21 out and connected directly to a SIM card. It is still not able to detect the SIM card. Will the PCB layout problem affect the SIM detection although I soldered the SIM directly to the SIM pins of EC21 ?
I did some more testing. I cut the traces from SIM card socket and directly solder the SIM card to EC21AU. It is still not able to detect the SIM card. I did the same work in a Sixfab shield it works. It may be the EC21AU problem. Can I get the latest firmware of EC21AU ?
It is impossible to determine the specific reason through your description, and you need to cross-verify by replacing the SIM card holder and other methods
@CarlosR_5COMM , thanks for your advice. I have done the measurement already. SIM_VDD is 0V, both clock and data are 0V without any signal. Ground is connected correctly to the main ground plane of the circuit.
It seems the close traces of USIM_DATA and USIM_CLK could be causing the SIM detection issue. Also, check if the firmware is up-to-date, as that could be another factor. For SIM-related issues, you might find helpful resources at TM SIM Registration.
It could be a PCB layout issue with the USIM_DATA and USIM_CLK traces being too close, causing signal interference. It might also be a firmware problem with the EC21-AU module. Make sure your TM SIM registration process is correct, as it could affect SIM detection. You can check more details at TM SIM registration.
During the testing of a product prototype using the EC21-AU module, several SIM card issues such as network registration failure and inconsistent connectivity were observed. These problems can hinder performance and require proper troubleshooting steps. For SIM activation or registration, you can visit new.globe.com.ph.simreg to ensure the SIM is correctly set up.
It sounds like your issue with the EC21-AU module showing “SIM Card Not inserted” could be caused by both hardware and firmware factors. Closely routed USIM_DATA and USIM_CLK traces can sometimes create signal noise, but it is not always the main reason. You should also check SIM socket pins, pull-up resistors, SIM voltage compatibility, and grounding quality. Firmware settings and SIM initialization sequence can also cause detection failure if not configured correctly. I suggest testing with another SIM card and comparing your PCB with the official reference design. Also, if you are working on SIM-related activation or testing, you may find useful info through globe sim registration link for SIM verification processes.
