Could somebody share me the latest andriod firmware for SG560D-CN thanks.
Model : SG560D-CNPA-U65-UGADA
My current Version is SG560DCNPAR60A01_BETA24042401_BP01.001_Linux5.4.86.01.001,
This is a beta firmware with Ubuntu system, It has some problem in wlan AP mode. I want to solve it by flash the newer Android firmware. It would be better if you can provide the latest Ubuntu firmware at the same time. Thank you.
Please provide the IMEI1 number of your model and your E-mail
IMEI1: 863564060289403
E-Mail: x@6mc.pw
Thanks you.
please check your E-mail , I have sent the firmware
Could you please share me the Android firmware at the same time? Thanks you.
When I use QFlash V7.5 to upgrade the module, it fails every time while the progress of (DL-Rawprogram( % ), percent files transferred % ) reaches nearly 100%. Now the module can not boot into system and directly enters 9008. I am using the QSM560DR dev board with SD560DCNPA-U65-UGADA .I checked the log and found an error with UFS. How can I solve this problem?
Do you have our E-sevice ccount? if so, please build a ticket for this problem.
I find you use the Qflsh to download the firmware, do you have QFIL tool?
I have used QFIL for flashing, but encountered the same issue and error messages like QFlash. I do not have an E-service account and I only have this EVB board.
Running UFS Provision can solve your problem, but it will result in the loss of baseband data. Please back up xqcn first.
