RTK between LC29H BS and LC29H DA. It seems that I already have the configuration for both the base station and the rover. Using the QGNSS application, I can see that the base station has the following messages: RMT 1005, MSM4, and MSM7. However, I will not use the application to establish the RTK connection, nor will I use a website like rtk2go.com. I will do it within Linux and over a Wi-Fi network. I am running tests but I am unsure how to view the base station’s information to then send it over the internet to the rover. If you can help me with this information, I would be very grateful. Best regards.
Hi @Jorge_Pardo
Please provide your email address and I will send you the relevant information via email.
Hi @george.gao
Did you also have any relevant information for LG290P BS and LG290P rover without QGNSS? I’m having problem connecting both module with script in python.
Hi @Jalul
What is the problem? Please describe the problem?
Please use QGNSS tool to download the firmware. QGNSS tool download link: https://www.quectel.com.cn/download/qgnss_v1-4
Hello @george.gao , thankyou for your reply. I want to use Quectel with Raspberry Pi. Both can be configured as base and rover. The base can send RTCM data using a local IP, and the rover can receive the data via Wi-Fi connection. Are there any relevant details on how to set this up using other interfaces without using QGNSS at all? As we know, I can’t use QGNSS on the Raspberry Pi. Because I need some data for tracking into a local Mapbox web map.
Hi @Jalul
We recommend that you refer to our RTK application guidance document.
Great, can you share to this email rijallul@synapsis.id. Thankyou
Hi @Jalul
I have sent you the relevant information via email, please check.
