Hi!
I’m trying to send a BRM message to a LC29D in order to get it’s configuration or change it.
I’m using the description from Quectel_LC29D_GNSS_Protocol_Specification_V1.0.pdf
However, I don’t get any response, ACK or NACK.
For example, I send “BRM-STP-MESSAGE - Set Message Rate”
Write B56206010300F00401F5D9
b'$GNGNS,013531.00,,,,,NNNNNN,00,99.0,,,,,V*1C\r\n'
b'$GNRMC,013531.00,V,,,,,,,010712,,,N,V*19\r\n'
b'$GNGNS,013532.00,,,,,NNNNNN,00,99.0,,,,,V*1F\r\n'
b'$GNRMC,013532.00,V,,,,,,,010712,,,N,V*1A\r\n'
I suspect my checksum algorithm is wrong. In the document:
//Buffer is the data array of which the checksum needs to be calculated.
uint8_t CHK1 = 0;
uint8_t CHK2 = 0;
for(i = 0; i < length; i++)
CHK1 = CHK1 + Buffer[i];
CHK2 = CHK2 + CHK1;
I implemented this algorithm and for me it gives:
byte = f0, chk1 = f0, chk2 = f0
byte = 04, chk1 = f4, chk2 = e4
byte = 01, chk1 = f5, chk2 = d9
It is different than checksum in QGNSS 1.5.2.
What should be the correct algorithm for the checksum?
My device FW version:
$PQTMGNSS,001*0C
$PQTMVER,MODULE_LC29DCNR01A01S_2WDR_HYF,2021/04/25,13:49:04*10
$PQTMVER,SUB_V02*3A
$PQTMVER,QL_SDK_V1.1.4,2021/04/25,13:49:04*5F
$PQTMSWCONFIG,1,1,17,55AA55AAC61BE69C000000000001FFFF00000000D9D8DA00640000000000000090D003000101640202010000010000000000000058595A000000000000000000*11
$PQTMSWCONFIG,1,2,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*13
$PQTMSWCONFIG,1,3,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*12
$PQTMSWCONFIG,1,4,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*15
$PQTMSWCONFIG,1,5,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*14
$PQTMSWCONFIG,1,6,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*17
$PQTMSWCONFIG,1,7,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*16
$PQTMSWCONFIG,1,8,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*19
$PQTMSWCONFIG,1,9,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*18
$PQTMSWCONFIG,1,10,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*20
$PQTMSWCONFIG,1,11,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*21
$PQTMSWCONFIG,1,12,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*22
$PQTMSWCONFIG,1,13,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*23
$PQTMSWCONFIG,1,14,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*24
$PQTMSWCONFIG,1,15,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*25
$PQTMSWCONFIG,1,16,17,00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*26
$PQTMSWCONFIG,1,17,17,000000000000000000000000000000000000000000000000000000000000000000000000*27
$PQTMIMUTYPE,2*4F
