SDC103A / RTL8852CU: supported RF inhibition during NCTL and IQK initialization?
Quectel email support referred me to this forum for technical assistance.
I am an independent developer investigating native macOS support for the Steam Frame wireless adapter (FCC ID XMR2025SDC103A, USB 28de:2432, RTL8852CU). The same adapter pairs and streams successfully with its stock Windows driver. I am not representing Valve.
Firmware boots in the macOS implementation, but holding global baseband reset prevents successful nonzero NCTL control/program-memory write/readback. We have stopped before releasing reset for further calibration because we lack a verified RF-inhibition procedure and do not have a shield enclosure.
Reference-source and saved host-transaction analysis indicates that calibration replaces RF0 mode0 with mode4, and selects KIP control of RFC through BB0x5670/0x7670 bit1 before the first NCTL command. These observations are not emission measurements or proof of RF isolation.
Could the SDC103A hardware/driver team clarify:
  1. Does shutdown selected through BB0x12ac/0x12b0 and BB0x32ac/0x32b0 remain effective while KIP controls RFC, including direct RF writes and NCTL activity? How can that be verified?
  2. Is there a supported sequence to release BB reset and access/load NCTL while RF remains inhibited? Can inhibition be retained during required IQK/other calibration and automatic responses, or is shielded/conducted testing required?
  3. Is there an appropriate register guide or initialization/calibration application note? If documentation is restricted, please advise the access process or engineering contact, including any required Realtek referral.
The intention is to preserve board calibration, antenna, regulatory and transmit-power constraints. No proprietary binaries, raw captures or personal/network identifiers are attached. A short technical answer or referral would help. English or Chinese replies are welcome.
中文摘要:Quectel 邮件支持建议我在此咨询。我正在独立研究 SDC103A / RTL8852CU 的原生 macOS 支持。保持全局 BB 复位时无法验证 NCTL 写入,因此尚未释放复位继续校准。请确认:KIP 控制 RFC 时,BB shutdown 模式是否仍有效;是否有在保持射频抑制的同时释放 BB 复位、加载 NCTL 并进行必要校准的受支持流程;如需屏蔽/传导测试或受限文档,请告知要求及工程联系渠道。我们希望保留板级校准、天线、法规及功率约束。
Sorry we missed out this enquiry, but can I first know where you get this product SDC103A from? Because I can’t find the relevant document regarding this product, I think this is an ODM or OEM products, and not from Quectel Standard Module Portfolio.
I will discuss with my RnD team to discuss on your issue, please expect few days before we confirm a solution for your use case. But I need a few clarification:
  1. What do you mean by “Steam Frame" wireless adapter? Can you share the link where you purchased this product?
  2. What is the Mac OS version you are using the product on?
  3. Mind to share your host system (laptop/desktop) system specification ( CPU, OS version, etc )
I think the issue stems from the driver within the product currently doesnt work with Mac OS yet, let me verify further with my RnD team in the meantime. I have also send you an email, we may follow up from there, and update the solution here once resolved for reference.
