I am trying to access the SD Card on the MC60E EVB board but unfortunately it is unable to mount the SD card. It throws ERROR.!
AT+QMSDC=1
ERROR
AT+QMSDC=1
ERROR
The AT command reference manual has only one command that just to mount and unmount.
Is there any application note that would guide us to achieve this?
Which type of SD card partition does MC60E supports ?
Dear Sir,
Just see that you use MC60E module to test SD function. I have double check with RD, MC60E module cannot support SD function, while MC60 module can support it. So if you want to test SD function, you can use MC60 module not MC60E module. Thanks!
Till now, we have no such plan to support it. It is mainly because the module have limited space to support so many function, and fewer customers use this feature. Thanks!
