SC668S-NA_UA Firmware / Update Guidance
Hey everyone,
I’m new to this space, so apologies in advance if this is a basic question.
I checked my IMEI and got the following:
  • Model: SC668S-NA_UA
  • Brand: Quectel
  • IMEI: 860274060542388
This is an Android stereo head unit installed in my 2017 Ram 1500.
The system options are very limited. It wouldn’t let me change the boot logo in settings. The seller sent me a file that successfully flashed a new boot logo, but the boot animation did not change, and they’ve since stopped replying.
I’m trying to figure out:
  • Is there an official firmware/update source for this model?
  • Are there recommended tools or procedures for flashing or backing up firmware?
  • Any documentation available for SC668S-NA_UA?
  • Best way to safely identify firmware version before attempting updates?
I don’t want to brick the unit, just looking for guidance on supported updates or customization options.
Appreciate any help.
Hi
Please be free to ask any questions there:
    → We can provide Quectel official firmware to you when can enable the model, but I am not sure it can enable all the functions in your device as it is built from customized function.
    → Yes, the QFIL to downloda but no tool to back up firmware
    → Yes
    → we have the AT commnds to get the origin Quectel firmware version in the device.
Please share your E-mail and what you want to us, we will send it in the E-mail later.
Thank you for your response.
Here is my device information:
Model: SC668S-NA
Hardware Version: V007-SC668S-NA-R01-DS
Android Version: 14
Build Number: 20251206-105854-W-QZD_G6_A13
I would like:
  1. Official firmware for SC668S-NA (if compatible)
  2. AT commands to retrieve the original Quectel firmware version
  3. Flashing guide for QFIL for this model
  4. Documentation/manual for SC668S-NA
Before flashing anything, I would like to confirm compatibility to avoid affecting MCU or CANBUS functions.
You can send the files to:
rstyllg@gmail.com
Thank you very much.
Please check your E-mail. And share the AT commands result to us.
Hi, sorry for the delayed follow-up, I only had time to install everything today.
I installed the QCOM tool and drivers as instructed and connected the head unit to my PC. I tried multiple USB cables and ports. The PC detects that something is connected but no COM port or diagnostic device appears. On the head unit itself, nothing is shown either.
When I connect a USB drive to the head unit it is detected normally, so the USB port seems to work. I also checked the manual and system menus but didn’t find anything related to enabling diagnostic/AT mode.
If there is a specific step to enable the diagnostic interface, I would appreciate any guidance.
Thanks again!
Please share the sceenshoot for the “device manager” when the USB conect to your PC.
open the “Ports” operation
It seems your PC doesn’t find the device with correct driver
Hi KlineMiao and Galbogain,
I have what looks like a close sibling of Galbogain’s unit — an Android head unit in a 2016 RAM 1500, same SC668S / QZD_G6 platform, though my hardware revision and build are a bit different. I currently have the unit set up on my electronics test bench with working wireless ADB access, so I’m well set up to run diagnostics or flashing steps carefully.
My system details:
Model: SC668S (Snapdragon QCM6125)
Hardware Version: V007-CUS-EM-R01-DS
Android Version: 15 (reported)
Build Number: 20260416-145755-W-QZD_G6_A13
MCU: 2026-02-28 STA_GT
BT: BLINK_6125_R_2025/10/28
Screen: 1200x1920 portrait
LCD: lcd_G1_vesa_1920x1200_4lane_mipi_sv1
I’d be very grateful for the same help Galbogain asked for, matched to my V007-CUS-EM-R01-DS hardware revision:
  1. Official Quectel firmware for my SC668S / V007-CUS-EM-R01-DS build (mainly for backup and recovery peace of mind before I make any changes)
  2. The AT commands to read the original Quectel firmware version
  3. The QFIL flashing guide and correct Qualcomm USB drivers for this model
  4. Any documentation/manual for SC668S
I noticed Galbogain’s thread stalled where his PC detected the USB connection but no COM port appeared under Ports in Device Manager. I suspect the unit wasn’t in the correct diagnostic/EDL mode, or was missing the Qualcomm QDLoader 9008 driver. Could you clarify:
  • How do I put this unit into diagnostic / EDL (Emergency Download) mode so the COM port appears? Is it a key combination on boot, an ADB command (e.g. adb reboot edl), or a hardware test point?
  • Which exact driver package should be installed for the port to enumerate correctly?
Since I already have wireless ADB working, if there’s an adb command or system property that triggers diagnostic mode, I can run it directly and report back.
I’m happy to share my email by private message whenever you’re ready to send the firmware and documentation, and I’ll gladly write up whatever steps end up working so it helps others with the same platform.
Thank you very much!
안녕하세요 여긴 대한민국입니다
대한민국 서울 주식회사 카카오파츠입니다
저에게도 펌웨어 재설치 파일과
mcu업데이트 파일을 보내주싷수 있나요??
besttinter@gmail.com
Can you share more information about your devices?
Please share your E-mail and the IMEI1 number of your device.
Hello KlineMiao,
I have an Alpine INE-AX810 Android head unit that appears to use the same SC668S / QCM6125 platform discussed in this thread.
My device information:
  • Model: Alpine INE-AX810
  • Android: 13
  • Screen: 1280 × 800
  • Storage: 256 GB
  • Hardware Version: V011-CUS-EM-R01-DS
  • System Version: 20241220-120524-QZD_G6_A13
  • MCU Version: 2024-09-18 10:27 STA_GT
  • Bluetooth Version: CQ231S.V2.0.20241207.1407 (blink_20241130)
I noticed that this unit uses the same QZD_G6_A13 platform and STA_GT MCU family as other SC668S/QCM6125 devices mentioned here.
The unit is a Chinese-market version of the Alpine INE-AX810. Alpine also offers an international version of this platform with Google services and multilingual support.
I am NOT planning to flash unrelated firmware, because I understand that the device contains customized MCU, CANBUS and hardware configuration.
I would like to ask:
  1. Can you confirm whether V011-CUS-EM-R01-DS is based on the Quectel SC668S platform?
  2. Is there an AT command that can identify the exact original Quectel firmware/module version?
  3. Can you provide documentation and the QFIL/diagnostic guide for this platform?
  4. Do you know which OEM/ODM develops the QZD_G6_A13 software layer used on these devices?
  5. Is it possible to obtain the correct firmware or recovery package specifically for V011-CUS-EM-R01-DS without overwriting the customized Alpine MCU/CANBUS configuration?
My main goal is to understand the platform and safely find the correct international firmware for this specific Alpine hardware revision.
I can provide the IMEI1 and additional system information privately if required.
Thank you very much for your help.
Please send the IMEI1 number which can help us check whether this device use our Quectel’s module.
Looking for the latest firmware for my unit. Having some issues with the functions becoming unresponsive.
Also, if anyone can direct me to a vendor who will sell me a motherboard for this unit, I would like more ram.
Here is the info for my unit.
• ​Android Version: 14
• CPU: Snapdragon 8-core 2.0GHz with Adreno TM 610 GPU
• Running Memory: 4GB
• Storage: 41.03 GB available out of 64GB total ROM
• Screen Resolution: 1200 x 1920
• App Version: 20260512-194042-N
• Build Number: 20260416-145755-W-QZD_G6_A13
• MCU Version: 2026-02-28 15:51 STA_GT
• Hardware Version: Hardware V007-SC668S-NA-R01-DS
• BT Version: BLINK_6125_R_2025/10/28-14:55:48
• ​BT Version: BLINK_6125_R_2025/10/28-14:55:48
• ​Canbus Version: CH V1.10.004BYPM
• ​Trackbox Version: Unknow
• ​LCD Info: lcd_G1_vesa_1920x1200_4lane_mipi_sv1
• ​Serial NO: 150100444836444d4205758118518900
• ​QR Code: G6a1e5643fe1a9bc0
• ​IMEI: 860274061229209
• ​IMEI2: 860274061229217
Dear, customer:
Sorry, we don’t have any information for this unit.
It’s hard to provide any vendor information.
I have a car head unit (sold as Nakamichi NAM5960 Pro-A9Z) built on the same QZD_G6 platform discussed in this thread. The cellular connection was blocked by the operator because the device is not homologated in Ecuador, and the regulator (ARCOTEL) requires the international certificate of the cellular module.
Device information:
Baseband: BP01.006 (CUSEMUAR01A06)
MCU: 2024-09-18 10:27 STA_GT
Platform: QZD_G6 / QCM6125 (trinket)
Based on this, I believe it uses a Quectel SC668S-EM. Could someone from Quectel please:
Confirm whether this unit uses a Quectel SC668S-EM module (I can share IMEI1 privately if needed), and
Indicate how I can obtain the EU Declaration of Conformity / RED certificate for the SC668S-EM (certificate number, notified body and verification link)?
I have also sent this request to info@quectel.com.
